AVS › AVS Forum › Audio › Receivers, Amps, and Processors › List of PWM Amplifiers.
List of PWM Amplifiers. - Page 12
post #331 of 357
Hypex Electronics is proud to announce that Meridian has decided to use our products in their new surround sound home cinema set.
"Meridian’s G95 CD/DVD-Audio/Video Surround Receiver System is the most powerful and versatile member of the company’s award-winning G Series family."
www.hypex.nl
post #332 of 357
TEAC AI-10 Integrated
post #333 of 357
Another affordable ICEPower alternative:
Wyred 4 Sound
post #334 of 357
Originally Posted by Ad-Rok View Post
Curtis et al,
Kevin at DIYCable.com has released his astoundingly-priced Hypex-based Exodus kits, which he will also assemble for a fee. I'm ordering a 5-channel UcD400-based kit today, and I will keep everyone posted. My first impressions are of clean and overbuilt parts, great instructions and layout, and shiny case.
This qualifies as an exciting addition to the Class D amplifer list, so thought I'd add it here.
This amp will be mated to my Ascend 5-channel setup.
I will keep all interested apprised of my kit build progress, likely in another thread.
Interesting mini-review here with this author stating that the amp supersedes his existing Odyssey Stratos, which I think is no small achievement.
Best,
Adam
Quoting myself because well, it's easy. So, I'm utterly embarrassed to say that I *just now* hooked this puppy up after moving across the country with it, getting soldering help from a friend, and replacing a quick fuse. To my ear-to-ear-grin surprise, I hooked the thing up perfectly. And OH MY was it worth it.
This amp replaces a Denon AVR-2801 powering my Ascend Acoustics setup, and I am still just sitting here, listening in awe. Can't really believe I paid what I did for this highest of high-end machines, and put it together myself.
Bravo Kevin, BRAVO!
Good news for Curtis: I'm in Santa Monica now bud!
Feel like a listen?
Best,
Adam
post #335 of 357
nuforce debuted their new micro 10Wpc integrated amp at CES 2008
downside is needing to crimp the speaker cable, but the package will come with speaker cables terminated with the appropriate RJ45 jacks
post #336 of 357
MHz class-d amp from huygens
100W ~ 250W class-d amp running at 1mhz
please add this link :mhzclassd.com
thanks
post #337 of 357
thanks
Hey Fumac!
Nice to see you here on avsforum. I spend a little time here myself.
Talk to you later.
post #338 of 357
I've also been looking for a "digital" amp hopefully in a receiver. Other than Panasonic, what are the options ? I have a few reasons for wanting a receiver.
I don't have huge speakers (orbs) and don't need 500w/ch.
Seperate processors seem to be big bucks whereas fairly sophisticated receivers (say the Denon 3808ci) are around 1K with all the processor features I need such as single HDMI connections for multi channel sound, streaming audio from ethernet, latest audio/video encoding etc.
Can anyone recommend a good/cheap processor ? Seems like for most of these setups, even if I get a reasonably priced amp, I've still got to shell out for the expensive processor. Or do folks use a receiver and just send the audio-out to an amp. I noticed that although Onkyo has this digital amp, they use a/b stuff in their receivers (which run extremely hot !)
Also seems like you must lose SOME sound quality converting D/A then back to D when you have a digital source but a separate amp with regular analog inputs. Maybe that's not too big a deal but if these amps are so small and efficient, I'd just assume have them in one box.
post #339 of 357
thanks
Fumac,
Any place to check out and buy amps based on your technology?
post #340 of 357
Originally Posted by kokishin View Post
Fumac,
hi kokishin
this is the pdf of the mcd-255 module
mhzclassd.com/MCD-255%20datasheet(test%20version%201.1).pdf
rg
fumac
post #341 of 357
fumac,
From your web site it sounds like your intention is to OEM them.
Are these available in any products yet?
I'd be interested in a 7-ch amp.
post #342 of 357
fumac,
wellcome to
bbs for mhzclassd:
bbs,class-d,net
post #343 of 357
Thanks for the link
post #344 of 357
I didn't see it mentioned in this thread. You might want to add it to post #1:
Axiom (www.axiomaudio.com) A1400-8 ICEPower 8x200w www.axiomaudio.com/A1400-8.html
The Axiom A1400-8 Amp AVS thread is discussing it in more detail.
post #345 of 357
http://gizmodo.com/387880/pioneer-el...-and-vsx+01txh
Pioneer's flagship A/V receiver, code named "Susano," has set the industry standard for home theater performance and its 2008 top-of-the-line receivers, the SC-07 and SC-05, continue to incorporate the Direct Energy HD Amplifier with ICEpower analog class D amplification technology to produce a level of multi-channel power output, fidelity, and efficiency never before seen or heard in a home A/V receiver.
post #346 of 357
DENON DRA-CX3
Not sure if this new AMP/Receiver is PWM from Denon, but it looks like it might be. Does anyone know anything about this?
http://usa.denon.com/ProductDetails/4171.asp
post #347 of 357
Arise
Here's hoping for an update to this list! Please!
post #348 of 357
mhzpower4 the first class-D running at 1mhz can output 400w rms
key words:high power, high frequncy ,class D AMP, 1mhz, DC couple, 400w, low THD, bandwidth,hifi audio,true balanced input, world votage
Type No.: MHzPower 4
Dimension: 235mmx90mmx320mm
Weight: 9kg
Max output power: 420w 4ohm, 250w 8ohm
inside the module is design by john.fu
post #349 of 357
post #350 of 357
August 2009 - Bryston goes class D - Bryston, LTD has announced that the first two of four new 8-channel zone amplifiers will be shipping to dealers by October 1st, 2009. The Bryston D-Series D-130Z Hybrid [$4,395] and the D-250Z Hybrid [$5,695] have been in development and many dealers expressed the need for a lightweight, high performance multi-channel amplifier for distributed audio and industrial applications such as bars and restaurants. Bryston uses the term hybrid in reference to the combination of class D amplifier technology along with a Bryston-engineered linear power supply.. "This is what our dealers have been asking fora multichannel solution built to Bryston standards," said sales VP James Tanner. "Although the D-Series is lightweight, highly energy efficient and cost-competitive with other multi-channel products, these amplifiers also feature input stages and power supplies designed by Brystonthese are world class audio products, Tanner stated. The Bryston D-Series is a reliable amplifier solution with low heat emissions for tight space applications such as the equipment racks and utility closets commonly found in restaurants, bars and nightclubs. Unlike most competitive industrial amplifiers however, the D-Series carries on Bryston's tradition of sonic excellence and durability.
Product Specifications:
D-130Z Hybrid Features:
Bryston engineered 2 x 650 watt linear power supplies
8 independent channels at 130 watts each into 4 ohms and 90 watts at 8 ohms.
4 stereo zones at 130 Watts per channel into 4 ohms.
All channels driven 130 watts per channel at 4 ohms.
Each individual zone bridgeable to 400 watts into 8 ohms
Level control on each channel
Each channel can select direct input (RCA), left bus only, right bus only or L+R (mono)
Stereo bus can be linked to other amplifiers
Each zone can be muted independently with 12-volt trigger
12-volt trigger for amplifier on/off
Soft-Start circuit to prevent high power in-rush current
Gold plated 5-way speaker binding posts
5 year warranty
Dimensions: width 19 x height 4.125 (3.5" without feet) x depth 16" including connectors
D-250Z Hybrid Features:
Bryston engineered dual 850 watt linear power supplies
8 independent channels at 250 watts each into 4 ohms and 150 watts at 8 ohms
4 stereo zones at 250 Watts per channel into 4 ohms.
All channels driven 200 watts per channel at 4 ohms.
Each individual zone bridgeable to 800 watts into 8 ohms
Soft-Start circuit to prevent high power inrush current
5 year warranty
post #351 of 357
post #352 of 357
New Class-D amplifier!
Arion Audio MK1000
review
...there is no doubt that the MK 1000 from Arion Audio has all the prerequisites to become a big success and this for three reasons: Firstly they have neutrality and very low noise despite their very high power, secondly they do deliver -exactly- that high power that will free them who have a difficult loudspeaker and/or big space and third they achieve all these at a comparatively reasonable cost.
post #353 of 357
Originally Posted by SiriuslyCold View Post
Pretty entertaining design, they literally put blocks of metal in the chassis to do almost nothing but add weight.
post #354 of 357
some audiophiles buy amplifiers by the KG
post #355 of 357
Might be needed or the weight of the power cord will pull it from the table / sideboard.
post #356 of 357
Apparently a hybrid class-A/D - Devialet D-Premier
post #357 of 357
Thread necro, because I want to know if 1) there are still new PWM amplifiers being actively developed and released and 2) if anyone has a new thread listing them or if SiriuslyCold is still updating this one.
As an FYI, this thread is also the primary reference external link on the Wikipedia article for the Class D amplifier. If for no other reason than this, I think the thread deserves an update!
Cheers,
Adam
