Originally Posted by millwood
that wouldn't be necessary: you can simply multiple a pwm or pcm or bitstream signals in the digital domain and then feed that signal to the amplifier. For example, multiplying the signal by a factor greater than 1 increases its volume and multiplying the signal by a factor less than 1 decreases its volume.
let me use a simple example. see you are dealing with a 4-bit pcm signal, which takes the form of 0110 (equates to a value of 6) at this particular moment. see you want to double its volume (to 12), you just shift it 1 bit to the left, 1100 (equates to 12). feeding that
signal to a class d amp (either directly or through a dac) will double the output voltage.
or you can shift it to the right by 1 bit to reduce the volume by 50%, 0011 (which equates to 3).
the same principle applies to your typical 16-bit PCM used by your CD, or DTS / DD signal on your DVD.
In other words, you want to do volume control or processing (of which volume control is a form) in the digital domain, and in the pre-amp section, not in the amplifier.
no need to alter rail voltage dynamically for a class d amp - too complicated and without any meaningful gain.
A very good point and it is logically sound.
However, this procedure will require tremendous processing. Imagine recalculating every bit (no pun intended) of information even with the slight change in volume (gain).
Each one of these digi-amps have a unique way of handling volume control. Equibit's approach maybe the best that I have seen so far. It uses PSVC (Power Supply Volume Control) which varies the (fixed) voltage of the PS via a controller built in the chip and is completely separated from the signal path therefore providing the cleanest unhindered volume control system.
