AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Maxent 50" plasma MX-50X3 official thread - DO NOT POST PRICES!!!
Maxent 50" plasma MX-50X3 official thread - DO NOT POST PRICES!!! - Page 2
post #31 of 2180
Ordered this in store this morning. It will be in on Nov. 2. I will post some info then.
post #32 of 2180
Review coming tomorrow.
post #33 of 2180
...waiting.
post #34 of 2180
I am picking it up shortly. I will try to post a review tonight.
post #35 of 2180
I picked it up. I would post a review but I have never had a big screen, so I dont know what to post. I will definitely take photo. What are some things to put in the review?
Also how can I tell what the internal panel is? I was hoping it was a panasonic like the 42x3.
post #36 of 2180
Grab a flashlight and look through the vent holes in the back. Do you see any markings or company names?
post #37 of 2180
I am not saying for sure it is a panny but it has the following number tnpa3562 which the only result on google was panasonic.
post #38 of 2180
I think this is the panel number: MC127H27D8
I got no search results.
post #39 of 2180
If it has a transparent logo like fox is that ok to watch in the first 100 hours?
post #40 of 2180
Good detective work so far. Do you see any large "M" markings? The M stands for Matsushita Corp., Panasonic's parent company.
post #41 of 2180
I don't think any short-term use of the PDP would be problematic. But, to be safe, read the FAQ about "burn in" procedures.
By the way;
Manufacturer Part#: TNPA3562
Manufacturer: PANASONIC (MATSUSHITA)
Description: PC BOARD
Are there any other internal numbers or symbols that you can see?
post #42 of 2180
I has an M like the bottom left image. And it is made in japan june 2005.
EDIT: I removed the image, jeremy posted it below.
post #43 of 2180
By the way;
Looking good so far....
For those who have this set home, what are your initial impressions?
post #44 of 2180
Picture doesn't work for me.
post #45 of 2180
Did you intend to post the Angelfire logo? While I can't say for sure, it certainly is possible that this Maxent is also using Panasonic glass. I'm sure others in this forum can help us find out. In the MC127H27D8 part #, you can't help but wonder if the "MC" stands for Matsushita Corp.
Enjoy your new PDP and keep us informed!
post #46 of 2180
No, he was using AngelFire to host the image and they don't allow linking.
I was able to get it to work and saved it to my own host. Here's the image he was trying to post:
post #47 of 2180
Picture looks very good to me but I havent been able to do a 720p or 1020i signal. I think the dvd player I have only puts out a 420p and my xbox games seem to only do 480p or 480i.
post #48 of 2180
The first two letters "MC" of the PDP panel model designation most assuredly means that the 50x3 plasma panel is a Matsushita/Panasonic part just as seen with the Maxent 42x3 plasma. The letters "MC" are also printed on the plasma panels contained in the current generation Panasonic-brand plasma televisions.
As you all get your hands on the 50X3's please calibrate them using DVE, Avia, THX opt, or other method and give us a report. I am particularly interested in hearing the opinions of anyone who owns or has owned a 42X3 or a Panasonic-brand plasma in addition to the 50X3 to discuss the differences in picture quality.
post #49 of 2180
Keep in mind the BB 30 day price guarantee.
post #50 of 2180
Still waiting for the reviews...
post #51 of 2180
I am willing to post a review but I am not sure what to right. I believe the picture is great and it is a panny tube. But this is the first big screen/HD I have owned.
I need some assistance on posting a review. What info do you want? I can post some picts. LMK.
post #52 of 2180
You could start with some of these:
1) How is the case design and remote?
2) In your opinion how do DVDs look? standard TV? HDTV?
3) On opening/closing credits when white text appears on a black background does the level of black change?
4) When there are images of solid color like blue sky or undersea do the blue areas look smooth or like they are made up of bands of color.
5) Do each of the inputs "remember" the aspect ratio settings when you switch back and forth between them?
6) Is the overall picture on any input biased toward green or red?
7) Do high definition images look "lifelike" or over-exaggerated?
8) Are the menus easy to use?
9) Are there any menus or features that you feel are missing?
10) Does the set make any buzzing sounds or produce excess heat?
11) Are the blacks very dark or somewhat grey?
12) Post some photos of standard tv, dvd, hdtv.
post #53 of 2180
I ordered this TV from Best Buy yesterday. It's scheduled to arrive Monday, so I'll provide a review of it on Tuesday.
post #54 of 2180
We'll believe it when we see it.
post #55 of 2180
I like the case. It is silver with detachable side speakers, and black in back. It has 2 sets on components, 2 sets of composite(each with S-video, 1xhdmi, 1xrgb, and a serial connection. The remote is a little flimsy and I really don't like that it has a slide door at bottom because you need those buttons quite often.
Standard DVDs look great. SDTV is pretty damn good. I havent got my HD service up yet.
The black level looks even during credits.
I did notice any bands of color.
It doesnt remember aspect ratio but it does remember picture settings.
I notice no bias whatsoever.
N/A
Menu system is a little clumsy but straight forward.
The features seem to all be there except I dont like the fact that there are only 4 picture setting: user, cinema, vivid and standard, you cannot create your own but you can change the settings in user.
There seems to be no excessive heat, and it is passively cooled. If you put your head behind the screen there is a slight buzzing but you cant hear it in front only in back.
The blacks are extremely dark, just about matches the black on the bezel.
I have some photos, I need someone to host them. Contact me on the PM they are ready to be uploaded.
I am willing to answer any other questions as well as take some more photos. This is a great set with extreme value.
post #56 of 2180
There are many free image hosting services. I sometimes use:
http://imageshack.us/
post #57 of 2180
TJ22, Thanks for taking the time to post these answers. I too am looking at the Maxent.
post #58 of 2180
Please edit this statement as the operative word in the sentence is missing so it could go either way. I hope you left out 'great' or 'remarkable' as opposed to 'bad' or 'grayish'
post #59 of 2180
This should tide you over until then
I smudged the prices since they weren't MSRP.
http://www.adam-snow.com/tv/plasma/maxent.gif
post #60 of 2180
No, I believe that you bought it. It was a shot at those who said the would post reviews on 'x' day and then didn't follow through... at least not right away. So, we believe you'll post a review when we see said review.
