Originally Posted by rfr
When I recently changed the lamp in my 62HM195 the light streak on my screen all but disappeared. My theory is that either there are subtle internal issues with lamps or the precise fit of the lamp assembly in its mount leads to the problem. The easiest way to test the latter is to use a very thin shim to slightly alter the position of the lamp when it's screwed into place.
Thanks Rfr! I see you're the one that had mentioned that the streak disappeared after replacing the lamp. I agree that this is a lamp related issue. I'll keep my eye on it.
repsher, did you speak with Chris at Toshiba? Did he tell you that it would still be another 10-15 business days once they figure out what they are going to do for you?
