The Laranberg Theater Begins
post #1 of 190
Hello fellow forum HT builder
I started this basement project about 4 months ago and it is going pretty good. There is alot left to do. Thought I would share some pictures.
The basement will have bedroom, kitchenette,bathroom,game room, Home theater and lobby.
renders from c4d
[/IMG]
[IMG]
[IMG]
the unstable testing chair
looking thru theater and into lobby
some images are poor!
left,center and right speaker conduit
post #2 of 190
rear of theater with the horn of plenty. outlet boxes that is.
equipment room
post #3 of 190
Good job and good luck. Finally someone with cleaner floors than me! Are you planning to do the drywall? What are your dimensions? Looks like there is an entrance on the left front?
Bud
post #4 of 190
hello chinadog
thank you.
one day i will be doing the drywall.
the room is 21.5 ft. by 14.5 ft.
the opening is the entrance to the theater. I will put drapes between walls. very thick lightblocking drapes. Possible motorized.
columns will be in and outside the theater. 6 total in the theater. they will be just for the look. No speakers or sconces.
post #5 of 190
the floors will get real cruddy when mudding begins. It is hard to be neat with that stuff.
post #6 of 190
an update
post #7 of 190
green glue yesssssssssss
post #8 of 190
some basement pic
looking from sliding glass door
looking outside the theater
beginnng stages of husebox
post #9 of 190
Wow! Very nice looking! There were definitely a lot of electrical boxes on that back wall!
post #10 of 190
Looking good Larry! Looks like you're right on my tail. See, told ya!
Bud
post #11 of 190
man china dog It is alotttt of work.
Doing the drywall in theater so I can finish the framing of tray(inspired by your tray) front speaker stages,rise for back row and other small jobs.
then there is the rest of the basement to drywall!
post #12 of 190
o yeah ceiling drywall hung by myself with the 3 hand method. That is the way to use your head. and the help of 2x4's supportting one side.
post #13 of 190
Sure is a lot of work, but very statisfying and saving a few bucks sure helps!
Bud
post #14 of 190
your not kidding.
when you do it yourself changes can be made on the fly without much difficulty.
color of paint ,molding type and etc.
post #15 of 190
who can answer this ?
who's theater am i using as a reference. the reference theater is hanging on doorway opening as you come into my theater.
for a million dollars the winner is!
post #16 of 190
Well, I saved one of your pictures and blew it up, but it's too damn blurry to tell..
Bud
post #17 of 190
Larry,
You are far too clean.
You say you are diying but I think you've got a crew of Oom-Pah-Loom-Pahs.
Looks great!
post #18 of 190
chinadog
regarding that picture, I think the owner will spot it. I should also thank him and all you guys for your info to help me on my way to finishing this theater.
thnaks again
thanks Milt99
I try to keep the work area clean. It makes it easier to fine that dropped screw or nail. Those can add up to BIG BUCKS!
i don't know about you guys but I think i have a record for dropped stuff. One thing that i find important is to tool up and retool for different jobs. I use one ladder for tools another for climbing.
post #19 of 190
beginnig of 90 sec. render with help of cinema 4D
post #20 of 190
Larry,
Looking good. Keep those pics coming
post #21 of 190
thankyou swithey.
post #22 of 190
Larry,
Looks good~!.... Did you insulate the walls or what are you planning on using for sound treatment?
post #23 of 190
61 flat-top
thank you
R25 IN THE CEILING AND R13 IN THE WALLS.
sound treatment after the theater is built. nice shaped sectionals to give the theater a design element .the basement and theater has angles and triangluar shapes.. After the columns go up i will put sound treatment on those.
larry
post #24 of 190
installing tray went pertty good. used finishing nails to hold up the frame. i don't have a magnetic tip so very little dab of liquid nail on the end of a 3 inch screw holds the screw to the tip of bit. Freeing up a hand while attaching frame to wall.
post #25 of 190
stage and some column pics
post #26 of 190
Nice theater Larry. I like the angled columns! I also like the trick of clamping the levels to the light tray. I'm going to build a similar tray to drop a rope light into and will have to remember that! Keep the pics coming!
Brian
post #27 of 190
Larry,
I like the angled columns also. I can't wait to see how they turn out!
post #28 of 190
Hey Larry,
Pretty cool. Is that the doorway to the theater? Did you plan on putting a door on it? The columns are cool as well.
Bud
post #29 of 190
thanks guys for the compliments
bud
That will be the opening to the theater. It will not have a door, just one or two very thick curtains in wall possibly motorized I have an outlet waiting in the wings just for that scenario. there will also be 2 columns outside the theater mirroring the 2 inside the theater.
after I built the columns it reminds me of the monster in the old bugs bunny cartoon that ran through all the walls leaving his body shape in every wall.
do you guys thinks i should put installation in the voids of the columns?
Larry
post #30 of 190
Larry
Larry,
My gut tells me it won't matter either way because they are such small spaces. BUT (there is always one of those), while the column is open, you might was well do it. It won't take much material at all to stuff them tight.
Steve
