Originally Posted by pgg
I have a MSI-K8NGM2-NBP motherboard with the Nvidia 6150 chipset that I want to use to make a simple network media player (mostly to playback DVD .iso files over our home network). Two questions -
First, this thread has mentioned, in a couple places, that the pinout for MSI's SPDIF bracket is wrong and needs to be tweaked. I didn't get a SPDIF bracket with the board, so I'm looking for one. (The MSI employee email cited earlier in this thread now bounces.) Anyone know if this MSI SPDIF bracket is compatible with this motherboard? Looks nice, since it has both coaxial and optical connectors on it.
Second, the intended display device is a Sony 24XBR910 HDTV. This motherboard has a DVI-out for the onboard video. Can I expect any problems with simply connecting it to my TV with an ordinary DVI cable?
Boy oh boy! This takes me back two years ago to when I installed this MB into my den HTPC. It's been there ever since; I upgraded it to a dual core Opteron at least a year ago.
1 - SPDIF out:
Anyway, I was part of the back and forth about this connector/ bracket etc. I simply made up a cable by splicing an RCA jack cable to a (I think) CD-ROM audio cable. I think I had to re-jigger the wiring in the CD-ROm connetor and cut off some plastic keying parts. If you are reasonably handy you can do the same, look back two years in this thread, search on my user name.
I don't think the bracket you linked will work because it also has an optical output. I THINK those brackets require +5V on the MB mating connector to drive the optical transmitter. The MSI MB conector only has SPDIF-Out, GND and NC. NC means No Connect, there is NO signal connected to this pin.
You really can't tell how many pins the connector in the link has. If it has more than three, it probably won't work w/o rewiring it. If you need to rewire it anyway, see the 2-year old stuff about making the cable.
I just bought a Foxconn version of this MB for $20 (after MIR) from Newegg. Has a similar connector.
2 - DVI. I feed my old Sony CRT RPTV via the DVI from this MB.
Good luck.
The CPU I've got for this thing is an old Athlon 64 3500, but that ought to be fine for DVD playback over my network.
