Originally Posted by Alan Gouger
VIDPP should only be used for video 60 frames source correct or does that yield results with movie material 24frames as well. Thanks!
Allan Jayne posted the same explanations I'd found...
"Use AUTO for film source 1080i. This mode uses 3-2 pulldown recognition falling back on motion adaptive per-pixel for the best results."
So it looks like Film should use AUTO, which incurs the 54 mS delay with audio. :(
When I turn on the V/F indicator flag, AUTO accurately identifies video (V) and film (F). The User Manual says
"the Lumagen processor allows the user to force deinterlacing to assume the source material is video". When I force DEINT to "VIDPP" or "VIDNC", I always get the "V" flag, even for Film sources. So, yes, VIDPP and VIDNC are for Video.
Jim's advice:
MEMA: genlock on, deint Auto (for Film)
MEMB: genlock off, deint VIDPP (for general video)
But after viewing HD concert clips tonight, I know the delay from AUTO is too much for me. And my audio system doesn't have any audio delay controls.
I'm trying to decide if I should keep trying to figure out these deinterlacing modes or try to return to my blissful ignorance of a few weeks ago when all I knew was that simple 1080p looks much better than 1080i.
Now that I've re-confused myself, I'm going to re-watch some film clips in the various modes.
