AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Boston, MA - Verizon
Boston, MA - Verizon - Page 45
post #1321 of 1500
Originally Posted by sfull View Post
I just signed up for Fios with TV, Phone and Internet - get top HD package with all movie channels except The Movie Channel which I didn't have with Comcast, and I'm not a big fan of anyway. .
Actually if you have Showtime,you will also have TMC.
you probobly also have Epix.
post #1322 of 1500
You are right, realized I have TMC last night. Didn't want or ask for it, but must have been bundled. Comcast had pulled it away from Movie package as carriage fees must have increased.
post #1323 of 1500
In regards to the new dvr,what is the best way to recieve this equipment.I take it you can't just go to the verizon store and swap out the old box for the new.Do they really charge you 39.00$ for the new box.When I had Comcast the upgrade was free and really simple and painless.
post #1324 of 1500
Yes you can swap them out at the store if they have them and it won't cost you anything. They didn't at mine and they charged me $40.
post #1325 of 1500
I called the store in my area and they said they were not allowed to swap out boxes.The women said they had them but I would have to order online first.And there is a 39.00 charge.WTF?
post #1326 of 1500
There is nno store I* can get to I have tried ordering it online for weeks and they won't let me.
I have called chatted and posted in the dsl reports Verizon direct area.
I keep getting the runaround
post #1327 of 1500
Ready to come back to Comcast
post #1328 of 1500
Originally Posted by kenvt View Post
ready to come back to comcast
not an option!
post #1329 of 1500
Why?
They're THIEVES
post #1330 of 1500
Fox Soccer HD is now on 584.
post #1331 of 1500
I noticed, that's nice!
post #1332 of 1500
Don't you have any friends with cars?
post #1333 of 1500
Everyone enjoying and satisfied with the Verizon Fios experience in MA?
post #1334 of 1500
Very!
post #1335 of 1500
Good and bad,
WLVI's Country channel (56.2) is now on Ch 465.
My questions on local channels are where are 11.1 and NECN-HD?
post #1336 of 1500
Good and bad,
Verizon is probably wise that Comcast's NECN HD has yet to air any actual HD programming and it's probably not worth licensing it for the Fios network. NECN still airs everything in widescreen SD, even the taped sports reports from its true-HD sister network, Comcast Sports Net NE.
post #1337 of 1500
I have been seeing issues with the SD Nickelodeon networks all weekend. It seems like the picture stalls for a second or so while the audio keeps going, then they get back in sync. When this occurs, i see blocking for a second then it is back to normal.
Anyone else seeing this?
post #1338 of 1500
Lots of pixelation on WCVB HD feed on 505 during 5:00 news tonight. Even getting the "channel unavailable" message a few times. Anyone else having the same issue?
post #1339 of 1500
There was an article in the Globe last summer about NECN-HD. Comcast stated that FIOS has the right to carry NECN-HD ,technical problems are currently preventing it
http://articles.boston.com/2010-08-2...el-rcn-verizon
Bring on channel 615!
post #1340 of 1500
Ok so I am thinking about switching from Comcast to FioS. I have specific issues I hope someone can answer.
Currently my verizon phone line comes in on the right side of the house near the power meter. I assume this is where they will place the FioS box. Currently my Comcast cable comes in far away on the opposite side of the house. My house is a slab ranch (no basement) and somehow the cable has to run from the FioS box to the cable at the other end of the house. Will FioS do what it takes to make this happen ? Or is this up to me ? It's not an easy task, cable may have to be run through the attic.
Thanks for the advice,
Ken
post #1341 of 1500
Ken
My guess is they will do whatever is needed. I just switched over a month and a half ago - install took almost 7 hours. Much of that time was spent outside the home and on the street. He had to run 500 feet of fiber down my street to get it to closest pole. Also of note, the Fios box needs to plus into an outlet - just be forewarned on that. They never mentioned that until the confirmation call I got the day prior to the install.
post #1342 of 1500
My Cable modem needs an outlet already, but it is NOT right where it comes in the house, there are a couple of splitters where it enters the house, and it runs about 30' away into another section of the house, at that point the Modem plugs in, and plugs into my wireless router(which Fios supposedly comes with)...
I've read that they come with a wireless router and a battery backup, so what do I need, 3 outlets where it comes into the house/splits into other areas?
Router= Needs a outlet
Battery Backup=Needs a outlet
Fios Eqpt= Needs an outlet(It's fiber, so it has to convert to Cable with a converter box I would imagine)- I imagine this needs to be right where the fiber enters the house/splits..
Does this sound right?
How big is the BBU (and weight)?
Anyone have a pic of the Fios install where it comes in the house?
I was considering reinstalling an old shelf in the area that they will enter the house(right next to the cable splitters in the back of the house), and running a power strip over to it, but I have no idea how big the BBU is, or how big the Fiber>Cable converter box is....
I like to be prepared for this kinda stuff so I am not being asked to do this and that when the technician arrives, I also like it when he has everything he needs right there so he can do his work and get out of my house.
Thanks for the info.
post #1343 of 1500
Others may help on the install stuff. I can give you heads up on programming.
HD Prime is pretty much like digital starter
HD Extreme is like digital starter with Digital Preferred but without Encore
HD Ultimate is like digital Preferred with SnE NStill no Encore but you do get showtime AND TMC!
Wave bye bye (for now ) to these HD channels:
G4 Style WENH HD NECN E! HDLN CBS college sports Cartoon TCM Hallmark TV one Ovation
Say hello to there HD channels:
ES.tv WGN america HD HD Net ESPN Goal Line Speed ch HD Fox Soccor channel HD
Outdoor channel 2 Yes HD (no live Yankee games) World Fishing Network HD MavTV HD Cars.tv Investigation Discovery Smithsonian Channel Nat Geo Wild HD Pets.tv Wealth TV HDTV My Destination.tv Recipe.tv Comedy.TV HD Net Movies The Hub HD Showcase Sho 2 West Epix HD HBO Comedy Action Max Thriller Max WMAX At Max Five Star Max OuterMax showtime West HD Showcase West Sho extreme west HBO West HBO 2 West HBO Signature West HBO Family West HBO Comedy West HBO Zone West HBO Latino West Cinemax West More Max West
NECN is now on channel 115 (Sd only)
PEG channels are on 36,37,and 38.
post #1344 of 1500
I'm looking at the Extreme package, but I MAY spring for the Ultimate because I did see a couple of channels that I wouldn't mind in HD.
Prime is out
I won't miss the channels that you mention.
post #1345 of 1500
Well, he mounted the Fios control panel to the wall in the basement and everything runs from there. With Comcast I had a phone modem and an internet modem. That's not the case with Fios, they supplied a new Wireless N router for wireless and there is no phone modem. As I didn't have an outlet where it made sense to place the fiber panel, the installer ran a connection to an outlet with a surge strip (I've since had electrician install a dedicated Fios outlet right next to panel). Fios supplied a wood panel to mount the Fios panel to (to overlap studs in unfinished basement area), overall he did a really good job. Again, you'll need power wherever that is placed, and just power to the wireless router and obviously the cable boxes. Be sure to ask/demand the newest boxes. 500 GB networked HD DVR - I had ordered that but they showed up with the older model. Was exchanged via another truck during the install. I hope this help - I can try to take a picture later as well.
post #1346 of 1500
I placed my FioS order today, I'll be joining your little group on the 26th !
-Ken
post #1347 of 1500
Welcome to the club. I can assure you that you will not miss Comcast.
post #1348 of 1500
I appreciate your input, did they end up using 3 outlets like I'm figuring on?
He installed a piece of plywood across the studs and then mounted to that, like a backboard?
A picture would be helpful if you can manage, I'll have it all set for him if I know what he needs.
post #1349 of 1500
Will the Verizon guys run cable in the attic if necessary or will i have to go up there and run it ? I think the shortest best route to the current cable will be that way.
-Ken
post #1350 of 1500
Another question. If I sign up for just Showtime ( I think it's 11.95 per month), is there a cancellation fee (like comcast charges) if i drop it after one month ? I just want to catch up on the latest season of Californication.
Ken
