I'm looking to buy a DVD player that upscales to HD. I found the DVD-HD841 refurbished on Amazon for a few ten spots, and I also found the DVD-HD850 - at nearly double the price, but new. I also found the Samsung DVD-HD950 HD Conversion DVD Player (Black) on Amazon, for a little under 2 bills.
Any reason I should go for the DVD-HD850 over the DVD-HD841? What about the HD950?
I've searched on here, and I see the hacks to play DivX on the HD841 (not something I needm since my modded Xbox is running Xbox Media Center aka XBMC), but I do need upconversion over component (since my HD STB is using DVI to HDMI cable, and my PDP only has one HDMI port.) I can't seem to figure out what exactly is the difference in the models. Anyone?
The Samsung HD850 seems to have gotten better reviews than the 841, and is only marginally more expensive ($99 refurb'd at Amazon, or $129.99 new), so that's what I'm going to try I think. Then again, I see on the link you provided, the "Holiday Specials" has it for $225, which isn't terribly bad...
