I just stumbled into a great buy on a (ridiculously old) 36" MM36100. Unfortunately, I don't know much about hi-def yet. I was wondering if anyone has had experience with this particular model they could share.
I have it working very well with DVD, VCR, standard cable, etc.
Now I want to try HDTV via my cable provider, but Im not sure what all I will need. My cable box has component out for the HDTV connection. The MM36100 only supports HDTV on the 15pin VGA input, I think.
Would a component to VGA adapter/converter cable work? Or do I need some sort of decoder, like the old DTC100 (made around the same time as the tv)?
Any help would be GREATLY appreciated!
Brent
Brent
