AVS › AVS Forum › Audio › Speakers › Please Join and post what speakers you have
Please Join and post what speakers you have - Page 111
post #3301 of 3367
A few more pics
The screen is in the close position (not watching movies).
Now the screen is the position of when we watch movies, the speakers are aperion Verus grand series (towers and center in this picture) and the subs are SVS PB13 Ultra
JVC RS45/X30 and some of the 4 aperion bookshelf
In-wall (Oppo103, Outlaw 7700 and Onkko PRS886 soon to be replace by Marantz AV8801).
The in-wall from the back
This one of my 3 cats, when it come to movies, he always come down to watch it with us while the other 2 are no where to be seen..
I
Some DIY speakers cable even if it is only to show a few feet
The entrance
Ray
Edited by darthray - 12/14/13 at 11:39pm
post #3302 of 3367
Sorry I forgot to put this one
Ray
post #3303 of 3367
Nice setup Ray!
post #3304 of 3367
Originally Posted by cavchameleon View Post
Nice setup Ray!
Thank you
Looking at yours show that you very serious about your sound.
Ray
post #3305 of 3367
Ray
That's ok, well let it slide this time. But next time get all your pictures right! tongue.gif
Nice stuff.
post #3306 of 3367
Thank you
Ray
Thanks, I try to be as much as I can - just wish I had a larger room to work with, but a small dedicated one is better than none...
Nice DIY cables by the way. I made mine also, much cheaper and works the same.
post #3307 of 3367
Ray
Nice stuff.
LOL, it was 1;30 am and since I could not sleep, got-up and decided to polish the speakers and takes some pictures and post them.
Also thank you for the nice stuff compliment.
Thank you
Ray
Big thanks
For the room size
We all have to work budget and room size, and I would say you did just fine with sound threatment.
I did spend lots of money for only2-3 feets (6-7 diferent banana plugs, also quit a few diferent sleeve and 3 diferent speakers cable to find the best one for my need).
Lots of money but the end result is worth-it, just like spending a few hundred for Outrigers for look and stability.
Ray
post #3308 of 3367
For the room size
Ray
Well, I have to say they look clean and nice (I didn't use any sleeves on mine, was fine with the look, but did use locking banana plugs also).
Thanks for the comment - all the sound treatment was due to the small room (and some think I'm crazy for doing 11.2 in such a small room, but it's still effective and fun!).
I didn't notice the outriggers at first, but now they really pop out. Are they from Soundocity (http://soundocity.com/products.html)? I had looked into getting some for my towers (noticed you also put them on your center stand) to make it easier to level and adjust. My speakers come with their own version of outriggers but are a PAIN to adjust (like most speakers, you have to do it from the bottom). I may have to get a couple pairs for mine! If you see the one's on the bottom of my towers, you can tell they are hard to adjust. The stands for satellites are easy to adjust though, they have long spikes and are tri-pod bottoms so very stable.
It might be more visible in the darker pic (upper one is with a bright flash). Someday I need to change out the carpet and put dark carpet in there. All speakers are from the NHT Classic series.
I don't want to clutter up by adding more pics since it's easily in my profile like you found.
Thanks again!
post #3309 of 3367
AVR Onkyo TX-NR809
Fronts Polk RTi6
Center. Polk CSi3
Rear. Polk OWM3
Sub Polk DSWPRO 550WI
Room 14x20
post #3310 of 3367
For the room size
Ray
Thanks again!
I think you did great for your room!
I did notice lots of sound threatment, and like I said , we all have things to work aroud (room size, I my case it was the floor concrete with 2 heavy carpet over each other, and this why I needed 2 more amp for the Buttkickers for chair since the bass will transmit anything to the chair).
And yes they are from soundocity and though, why not not for center speaker stand.
Quit expensive but they are worth it due to the nice craftmaship.
Ray
post #3311 of 3367
Home theater:
Front L/C/R: Thiel MCS1
Surrond: Thiel PowerPlane
Surround back: Thiel PowerPoint
Subwoofers: Epik Legend (2)
Everything else: Onkyo TX-NR10009, Oppo BDP-95, Darbee
Stereo room:
Speakers: Thiel CS2.4
Amp: Mark Levinson ML-334
Pre-amp: Eastern Electric Avant (tube pre, truly amazing!)
CD transport: CEC TL-1
DAC: MHDT Havana balanced
Turntable: Clearaudio Champion with Grado cartridge
Phono stage: Musical Surroundings Nova
All cables are Cardas
post #3312 of 3367
I'll join the fun.
L/R: EMP TEK e55ti towers
Center: EMP E56ci center.
Side Surrounds: Sony MBH-100 (bookshelf speakers)
Rear Surrounds: KLH 911b's
Sub: BIC F12.
AVR: Denon 2112ci
I've been working the last two years on upgrading my speakers, so far I've completed the front sound stage and the sub (though in due time I'm planning on upgrading the sub again). This year I'm going to turn my attention to the surround speakers. I'm leaning heavily towards the Monitor Sliver FXI speakers for the side surrounds, and likely the EMP e5bi speakers for the rear surrounds. When all that is done I would like to trade up the sub to a HSU or SVS model, but that's a few years off.
post #3313 of 3367
Home theater/two channel.
Martin Logan Aerius-I's for L/R
Martin Logan Cinema center
ML Motion FX surrounds
Dali Concept 2 rears
Chase Cs 18.1 sub
Velodyne DD 15 sub
Onkyo HT270 as a pre/pro
Outlaw 7100 amp pushing all speakers but L/R
Aragon 4004 amp for L/R mains
Mitsubushi 73" 3d DLP tv
Sony 3D blue ray (don't remember model#)
Direct TV sat
Pro-ject carbon turntable
Little Bear phono tube preamp
Nakamichi MB2 CD player
Alan
post #3314 of 3367
Originally Posted by AllenA07 View Post
I'll join the fun.
Sub: BIC F12.
AVR: Denon 2112ci
Thread is pointless without a picture right?
I know the wires are a bit messy, this picture was taken a few minutes after I installed the center channel, and I hadn't yet cleaned things up. I'm going to clean it up this weekend, and then possibly start a thread over "show off your gear" board.
post #3315 of 3367
Not near as impressive as some, but I sure love it!
Panasonic 60gt50
Yamaha rx-a2020
Focal Chorus 726v (2 fronts)
Focal Chorus cc700v
Outlaw LFM 1-plus (hopefully add another this year)
Polk owm5 (4 surrounds)
Basic panasonic bluray
Pioneer 101 CD changer-from 1999 and still going strong
post #3316 of 3367
HTD Level Two towers, center, bookshelves....
post #3317 of 3367
Read my sig!
post #3318 of 3367
Speakers i have now.
Hsu Research HB 1 MK2's
Hsu Research HC 1 MK2
Hsu Research VTF 3 MK4
"Side Surrounds" JBL ES20's
post #3319 of 3367
Raw Acoustics Lambda Line Arrays with powered CSS XBL 8's. CSS WR125 mids and Aurum Cantus G2 ribbons (open baffle AE OB15's have since been retired for a single Rythmik FV15HP). All Sapele Pommele ribbon veneer. Matching center channel on the way smile.gif:
Tower rears:
Edited by Emetw - 3/1/14 at 1:48am
post #3320 of 3367
They're not set up yet but here they are!
post #3321 of 3367
i have EPOS M% speakers purchased second hand & i have been told they have wrong tweeters  can anyone help with the color they should be, i have told gold color & silver color , did they use both, thaks in advance
post #3322 of 3367
It would be helpful to give a number rather than a % after the M as they have many M series also do a search as most reviews show pictures. Consider also e-mailing manufactures support they should be happy to give you the data.
post #3323 of 3367
post #3324 of 3367
sorry speakers are M5
post #3325 of 3367
Here are some oldies but goody's, JBL XPL's.
post #3326 of 3367
Those JBLs are some sweet classics!!!
post #3327 of 3367
In my opinion, the best speakers I have ever heard are Sonos. Sonos even sounds some what better than Bose to me. I have never heard such quality in my music like the Sonos Music System. I have only bought the Bridge & the $199.99 speaker & it sounds awesome. Just from one speaker it sounds like a full fledged system from back in the day. I am really impressed with them. I would like to get the expansion bridge for the rest of my audio equipment. That is $349.99. I just got the internet bridge & one speaker to start out for $250.00. I would greatly recommend Sonos to everyone. They are somewhat expensive but not thousands of dollars to what some music fans spend. They really make your house or apartment look modern & futuristic. I love them smile.gif.
05_System_ImageCarousel_desktop.jpg 72k .jpg file
post #3328 of 3367
I'm glad they sound better than Bose... wink.gif Bose the reference of all speaker con·nois·seurs...
post #3329 of 3367
^^^ ENM7073 ^^^
My son has the same Sonos system as you. Save up for the Sonos Sub, It will add even more depth to your music. and welcome to AVS,
You have come to the right place for "Bose Jokes"... (I love humor smile.gif)
post #3330 of 3367
Here's my 1971 vintage 901's.
These are Series I. I updated the EQ with a new set of caps.
These had the fabric surrounds that never seem to deteriorate.
This is my second system in the living room. Have since sold off all of the Carver separates in the rack.
Yes that's an old Sony 27" tube TV. Weighs a ton.
Edited by mhrischuk - 2/9/14 at 5:57am
  Back to Forum: Speakers
