After trying to sort through all the gyrations required to make a 16.9 projector into a 2.35 projector (scalers, anamorphic lens, etc), does no one make a native 2.35 projector?
I am probably missing something obvious and apologize in advance.
Seems like it would be cheaper to own both rather than all of the effort and cost associated with making a 16.9 projector adjust to a 2.35 projector.
Yeah. that was my initial reaction too. However there are no native 2.35 chips on the market AFAIK. So for now we must go through the gyrations of scaling and lenses...
4096 pixels horizontal x 2160 pixels vertical. This is slightly more than four times the number of pixels of high definition video (1920 x 1080).
It could be configured to run 4096 x 1742 to deliver 2.35:1 without a lens, but would be better as a 4096 x 2160 + anamorphic lens. Besides, at that price point, where's the conern with the cost of an anamorphic lens anyway?
I would say that is where we are now, though I would NOT call myself (or anyone else on this 2.35:1 forum a "whacko enthusiast". We're just a few steps ahead of everyone else...
I would say that is where we are now, though I would call myself (or anyone else on this 2.35:1 forum a "whacko enthusiast". We're just a few steps ahead of everyone else...
Yes, but the major CE manufacturers haven't yet caught up to serving us. We have a few of the very high end with very expensive solutions (Runco. Can we say Runco on this forum yet? I haven't mentioned it for several years don't know if Runco is still off limits).
And, small business like Panamorph providing interim solutions. I won't consider us TRULY served until one can go to a Best Buy or something and buy a 2.35:1 ratio Plasma or something.
We'll know things are REALLY good when the Sales Drone says "You don't want to buy that, you'll have GIANT black bars on both sides when watching Survivor: California; we only have a few wild eyed scraggly types (who resemble fat economics professors) who purchase THOSE weird things."
I am just curious: who made the decision having 16:9, a completely new format, instead of using 2.35:1, an existing format, when HDTV was first designed? Why reinvent the wheel or introducing additional format to make everybody, the movie studios and consumers more headaches??????
16:9 was a mid-point compromise between 4:3 and 2.35:1. At either of those two extremes you get approximately the same amount of black bars on screen. A native 2.35:1 screen has huge black bars on the sides of 4:3 content. The reason 16:9 was chosen rather than 1.85:1 had to do with various engineering concerns in regard to CRT tube displays (16:9 is 4:3 squared).
35mm film has a negative aspect ratio of 1.37:1. Movies are projected theatrically at either 1.85:1 or 2.35:1. 16:9 is a TV standard, not a theatrical projection standard.
1.85:1 movies are photographed "full frame" on 35mm with the intention of matting the top and bottom of the picture to achieve the desired widescreen composition.
2.35:1 movies can be photographed one of two ways: either using Super35 which uses matting much like 1.85:1 movies do, or using an anamorphic lens on the camera which squishes a wider picture onto the 1.37:1 negative. In either case, the theatrical release prints are printed in squeezed format and must be unsqueezed by another anamorphic lens on the projector.
There is no such a thing as "native" film projectors. Whether film projection is 35mm or 70mm (and 16mm and Super-8mm for that matter), lenses are what makes the difference.
Put this way...if "flat" movies (1:85:1) are projected a given size spherical lens is used.
If the movies is scope (2:40:1 now days and since the late 70s), then an scope lens attachment is put ahead of the primary spherical lens to do the "unsqueezing" in order to return the image to its normal geometric form.
By the way...please note that there was only one 70mm anamorphic film format ever devised: Ultra-Panavision. All other 70mm processes were done with spherical lenses...
I just read (and saw a picture) of this in German magazine AudioVision where they announce that Canon will be bringing out an LCOS projector with 2600 x 1000 in the future. No further information reagarding time-frame or price was included.
Interestingly, the article quotes Dr. Powers as saying "Had the SMPTE working group been aware in 1984 of the full-frame (soft mat) protection scheme, it is by no means obvious that 16x9 would have amassed the advantages over 4x3 that persuaded the working group to make that choice."
Fit projectors with anamorphic lenses people can fiddle with?
Or build a wider DMD. Change some inboard optics and processing power. And the projector would do 2:35:1 CH with a push of a button, or even automatic, responding to a flag in the source material.
I believe the first projector that comes with an 2:35:1 DMD for a reasonable prize would be wildly popular and set standard for the whole FP industry.
Edit: Cut and corrected my wrong numbers as Mr.Poindexter pointed out below.
coolscan, you lost me. A 2:1 DMD would still either need an anamophic lens or will not use the full resolution when showing 2.35:1 material. I would be able to project in 2.66:1 with it and that is about the extent of the benefit I can see.
Also anamorphic lenses are standard in the film industry (and D-Cinema is to be treated the same) and using the lens means full panel for both ARs not just the larger one. And the same rule should apply for the home. Full panel = brighter images and why I have started to use the pass through mode for 1.78:1 instead of stretching 4 x 3...
I have edited my previous post, but want to add this:
A 2:35:1 DMD would do the same job as a 16:9 DMD with anamorphic lens, using the same vertical resolution for both AR.
The need for anamorphic attachment lenses would disappear.
Anamorphic lenses have been used in cinema projection for nearly 50 years.
They are not without problems in the professional environment of film projection.
Now they must use anamorphic lens in D-Cinema also because of the lack of 2:35:1 DMD.
The more optics you put in a picture path the more possibility there are for optical distortion.
The average HT projection owner would not need to handle and adjust an anamorphic lens attachment.
Every time you start a film, as a response to a flag on the disk, the correct AR will be displayed on the screen in its full vertical resolution without involvment of an anamorphic lens.
Coolscan, if you have a 2.35:1 projector, you will still need an anamorphic lens if you want to run 16x9 material full panel. Digital cinema will have one of two things happen:
1. A different projector for each aspect ratio film - not very likely!
2. The same projector with different lens attachments for each aspect ratio - been doing it for 50 years!
As it stands right now, you can have exactly what you describe - the correct AR displayed on the screen without any user interaction. You just have a lens there.
The need for anamorphic lenses will never disappear - trust me on this. Even if you had a native 2.35:1 projector, you are going to need an anamorphic lens on the widescreen HD cameras unless you think they are going to make 2.35:1 HD video cameras as well.
Its to do with brightness or light out put. We all know that max out put is obtained by using the full panel. So as has been said, the full panel is used for both ARs. The lens is simply there to correct geometry...
Maximize light output or resolution or both. For those with a projector that is easily bright enough it becomes about maxing the resolution.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
