Originally Posted by noah katz
Glenn,
Aren't primaries monochromatic, i.e., points in the CIE color space?
So you're saying a point in that space can be represented by various combinations of multiple other colors?
The standard primaries are defined as single points in color space. They are not defined as single wavelenths of light.
Our whole video system is patterned after the function of the human eye/brain. The eye has three types of color sensors (three types of cones). One type of cone is most sensitive to Red light, one to Green, and the last to Blue light.
When light falls upon the cones, each cone is stimulated in particular way. This stimulation pattern is interpreted by the brain as color.
The points in CIE color space represent specific stimulation patterns (which is just another way of saying that they represent specific colors).
Any particular stimulation pattern can be created by a variety of different light wavelenth combinations. That is why three lasers (R,G, and B) can be used to create the same stimulation patterns in the eye as xenon light that has been filtered into R,G, and B. The lasers in combination will be comprised of just three wavelengths of light. The filtered xenon light in combination might be comprised of 400 wavelengths of light. Yet, they can both ellicit the same stimulation patterns in the eye, though through very different spectral signatures. When this happens, you can't see any color difference.
The CIE has defined the exact points in color space for the R,G,B primaries. If a display has accurate primaries, it will make accurate color provided that all the other ingredients (color decoding, gamma tables, etc) are executed properly.
Glenn
