AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Anyone use Audioquest? Not for the "wires makes no difference camp".
post #1 of 134
hello all,
I have experienced Audioquest DBS system for the first time. I will go to say I'm truely Impressed already. I have heard the same exact system(Krell 400i Intergraded, Focal Jm lab speakers, Krell Sacd Standard cd player) wired with balanced Monster m1000 balanced IC and THX speaker wires then with Audioquest Rockevellers and Jaguars Balanced Ic's.
Man I couldn't believe it was the same system. It sounded like someone cleared up the mid range and added clarity to the highs. The bass seemed more mellow and clear. I will say a level of balance was added to the system.
I'm curious who uses DBS Audioquest and what you wired with it. Even non DBS Audioquest. What made you pick it over all the other high quality brands?
thanks in advance,
mantis
post #2 of 134
I work at Best buy as a in store tech ( in store tech for displays and electric and just about everything ) We have a magnolia and all of my gear has audioquest everywhere from diamondbacks to jaguars and cv-8 speaker wire with dbs . I believe a cable only gets so good then it just becomes BS , as long as it has decent geometery it will be just as good as any 10,000$ cable. I can see a difference between cheapy componet cables that came with my denon 3910 and the YIQ-5's i have , but i dont see a difference between my YIQ-5's and some acoustic research ones i have lying around. But sence i get a employee discount through the manufact.. i get them for very very cheap , so i just get them to know i have reference cables.
post #3 of 134
And just where did you hear this?
post #4 of 134
If you did not hear the exact same setup in the exact same room while blindly switching wires, your claims have no value
Copper is Copper, wire is wire
post #5 of 134
Did you happen to see the thread title??? Here is the relevant part:
John
post #6 of 134
John, someone can't post a thread titled "I bought Bose, congratulate me" and expect that to happen.
Davdev makes a good point - one that many people don't remember or understand. For the record, I believe that wires make a difference. They cost different amounts, and look different.
post #7 of 134
Not even a close comparison. The OP asked that those in the "wires make no difference camp" avoid crapping on his thread, so why not be considerate enough to honor his plainly stated request? Doesn't seem like that much to ask...
John
Mantis10 - There was an interesting article in S'phile in the last year by Art Dudley about the DBS cables. He didn't feel that there was a diffrence with or without the batteries. Did you compare them both ways?
John
post #8 of 134
John
So do you disagree that unless everything else was set up EXACTLY the same way his statements are inconclusive, to say the least?
As for the "relevent" part, I don't care. If someone makes a post claiming that something made a huge difference, he should be prepared to back it up. And again Copper is Copper
post #9 of 134
And again, I'm just wondering why the OP can't be extended a little common courtesy and have his question answered? Since you state "copper is copper", I'm going to go out on a limb and guess that you are in the "wires makes no difference camp". What part of "Not for the wires makes no difference camp" don't you understand?
John
post #10 of 134
I heard this in a Tweeter Store.
mantis
post #11 of 134
I did hear the same exact system, at the same exact volume with the same exact cd, in the same exact room at the same exact 70 degrees, with the same exact ears with the same exact chair I was sitting in and I even used the same exact remote to restart the track.
Unless you have conducted these types of demo's and own gear that you could hear the little differences that make up the overall experience of ones system, then you my friend should.
I agree Copper is Copper, there the same exact word.
I'm not here to start any pissing contest with you sir, so If you have your own personal vaild claims to hearing no differences in all the different cables you have demo'd , then please post on other theads. I want to talk about my experience.
mantis
post #12 of 134
John
John
No I didn't. I don't even know if the DBS system is the reason for the higher quality sound I experienced. Audioquest uses pretty simple technology. They use solid conductors instead of Stranded and use a higher quality copper then ox free.
the batteries seem to charge the Diaelectric. How and why they came up with this you can read on there website. www.audioquest.com
If you unplug the battery , the wire stil has the charge. I believe you would have to wait a certain number of days or weeks before you could try the same cable again. It would be better to have 2 of the cables testing and try one with and one without. That would be really fun.
mantis
post #13 of 134
Again I ask you, have you made your decesion on the fact that your system, you went out and tried many different cables and found they didn't Improve or hinder your performance in anyway? I ask this as I have experienced differences in sund when changing out cables. Some good and some not so good. It seems to me no one can explain exaclty why it would or would not. I have read more theads and history on wire then most sane men. But I really want to know how people like you come up with your theory and why you feel the need to call me a lier. Basically thats what your doing.
mantis
post #14 of 134
Did that. It was less fun and less satisfying than you might suspect.
http://stereophile.com/cables/804aq/index7.html
Kal
post #15 of 134
You might find the following articles in Audioholics of some interest.
http://www.audioholics.com/FAQs/Audioquest.html
http://www.audioholics.com/techtips/...quest_DBS.html
post #16 of 134
Doesn't anyone question this?
Air is a dielectric...how do you prevent it from being charged by all these 'naked' outlets?
post #17 of 134
Hey Cal, Chu and Tony can't you see the OP only wanted people who would blindly follow his claims. Don't you know it's rude to disagree when he so clearly said that he only wanted people who agree with him to post here :) :) :)
post #18 of 134
my monster ref 2 interconnects already serviced me for 20+ years and i am not going to switch to audioquest
post #19 of 134
It is good to be serviced.
post #20 of 134
Depends on who is doing the servicing :)
post #21 of 134
just to show op that monster attract more attention than audioquest :-)
post #22 of 134
I would not pee on someones thread when politely asked not to. It is not polite.
post #23 of 134
Kal
Kal ,
Thanks for the link. It was a good read.
post #24 of 134
Chu Gai,
Thanks for the links. But i ahve to agree with Audioquest, if you don't sit and listen for yourself, then how can you deside that a cable sounds better or not? Spec's are spec's in my opnion. Cable companies claims can mean all they want, a test can proof better or worse but If I can't hear it , it means nothing to me. The batteries on Audioquest in my personal opnion is very hooky. Just like MIT and Transparent find the need to add things to there cables to make them work. I'm not a fan of this.
I like Kimber Kable due to there straight forward design. Simple and effective. but again most people in here turn there noses up for whatever there reasons are. If any of you guys told me that you personally tested what you claim, I can have much respect for you. Calling me a lair and all the other crap I read in here makes me feel like an outsider.
Thanks again for the link,
mantis
post #25 of 134
Why would you blindy follow my claims? Where does this come from? This is my experience. Yoou must have your own. My thead isn't to have people running out to buy Audioquest. Only to share with my fellow Audiophiles my experience. I thought that this is what these forums are for.
If you here just to bash my thead , then please post somewhere else. If you want to talk about your personal experience with Audioquest or any other wire for that matter, your very welcome to talk about it.
mantis
post #26 of 134
Then again, if you live to pee, feel free. It's a pee'ers world. Be proud, live free, pee wildly! The american way...
I don't know why people like that post in here. Is it sheer boredom? I mean if you have personal experience with Audioquest and found it not to make any difference in your own system, then please speak up. Run around talking about wire is wire and copper is copper I find close minded. But hey it's there system they want to believe and do this with is completely fine with me. I have found wire made audio difference for the better and worse in my systems over the years and like any other upgrade I do, I like to talk about it.
Audioquest is new to me and I'm Curious about the batteries and there solid core construction design. I already own very high quality cables all in my system(Kimber Kable) and I find them to work very well with what I own.(Dynaudio and Rotel).
mantis
post #27 of 134
I love AudioQuest, I have been using their cables for years. I am not going to make any wild claims other then I noticed a big difference in my audio and video when I switched from Rat Shack cables to AudioQuest. Can I prove it, no, it's just my opinion, based on my experience with my Home Theater. I wouldn't wire my Projector or Paradigm Reference speakers with anything else.
I have a friend that has an nice two channel setup, that loves the DBS cables and swears by them.
Redhouse
post #28 of 134
Though I tend to lean to the side that cables do matter, here's a thought for pondering:
If all characteristics of electronics are measurable, like Audioholics claims in their cable testing, then how do you account for widely accepted examples of things like soundstanging and imaging in speakers? I've never seen measurements to determine the existence or non-existance of those, but I've never seen anybody denying the differences in soundstaging and imaging between various speakers.
My intent really isn't to take a side, but I was listening to my Studio 20's tonight, and the question occurred to me. So, any answers?
post #29 of 134
thats because fr graphs, waterfall charts etc only tell you about macro dynamics while the subtle differences are in micro dynamics
quote from Arthur Salvatore:
"THE PROBLEMS WITH MEASUREMENTS
All audiophiles should at least once bring an accurate sound-level pressure gauge into their listening rooms. This is especially important for those music lovers who listen mainly to acoustical music; classical, jazz, folk etc., like me.
After an evening of listening to different music and observing the meter, most audiophiles are very surprised at how low the dB readings are on the gauge; usually between 60 to 85dB. It will on occasion go lower, and only for extremely brief instances will it ever rise above 90db.
Much more important than the pure numbers are the ultimate implications of all this. What do these surprisingly low dB numbers really mean for the on-going scientific and practical attempts of measuring a component's ability to reproduce music?
They are devastating, and here is why.
Let's start with a speaker of fairly high sensitivity, which is the trend these days and also what I recommend above. Let's say the sensitivity is 90dB/1 watt. This means that at an 80dB loudness level, this speaker is receiving a total of 1/10th of 1 watt of power from the amplifier.
This is the point where most audio magazines stop measuring, but this is the exact point where they really should begin "fine measuring", because the 80dB is only the peak/accumulated loudness at that moment. All the real, fine musical details and information; the harmonics, decays, sense of space, dynamic inflections etc. are still 20 to 30dB (or more) below the 80dB peak.
What does this all mean?
The truly unique and distinguishing musical information is being reproduced with only 1/10,000 of a watt or even less power!
At a softer 60dB loudness level, which is not that unusual, the power level of even 1 Millionth of one watt becomes important!
Which audio "tech/guru" or scientist measures what is happening in an amplifier from 100th to 1,000,000th of one watt?
The Answer: Not even one."
if there is no difference then why not use different cables (be it interconnects or speaker) to hook up your L and R channels and live with this setup for few months?
and how many advocate blind tests actually participated in one and choose their equipment after they have done the blind comparison tests?
post #30 of 134
That's a logic I've heard before too, but never heard explained quite as well as you did. It's the idea that the human ear is the most sensitive instrument known to man, and can sense and even make important differences beyond any normal attempts at measurement.
So I assume you believe cables do make a difference?
This thread is locked
