*** Moderators please read - I have cross-posted this here & on HTPC as I feel it are 2 very different forums which can possibly hold a solution for this ***
Has anyone information about this?
I.link receivers are actually integrated "sound cards" with amps - are there drivers available for Windows systems that present the receivers to the computer system as 5.1 or 7.1 capable "soundcards" ?
This would be nice for HTPC - instead of going analog & digital again, straight directsound output to your receiver.
Did anyone try to hook up i.link audio stuff to a PC and see what gets discovered?
Only link I found that even slightly hints in this direction is this one...
ASIO/WDM Driver for Professional Audio Devices with IEEE 1394 Interface
Thesycon designed and implemented a generic device driver that is used for a set of professional audio devices with IEEE 1394 interface. The driver provides an interface to ASIO, WDM and GSIF. The driver implements isochronous audio streaming according to the following standards: IEC 61883-1, IEC 61883-6, IEC 60958-1, IEC 60958-3, IEC 61937-5.
Furthermore, the driver implements AV/C connection management and an AV/C controller according to 1394 TA specifications.
The work was done under contract to a client company.
Thanks for all info on this subject.
PS. Seems that the latest OS X versions have a firewire audio core driver that might have this capability.
__________________
Yves
NEC HT1000/
Yam DSP-A2/Hypex Stereo UCD400 DIY amp/Pio 868Avi/
2xB&W Nautilus 804/1xB&W Naut. HTM2/
2xB&W Naut. 805/Yam SW300
__________________
Yves
NEC HT1000/
. Why? It is a question to Pioneer engineers. It was not so difficult to implements something like Word Clock (used in professional devices to avoid the jitter through SPDIF or AES/EBU connections), at least as it had been done in 59TXi.
