I have a 2WIRE 1800 Home Gateway. It has 4 ethernet ports and wireless connectivity. I ran 40 feet of cable to my office, and connected the 360 to one of the ethernet ports.
Then I downloaded Windows Media Connect from www.xbox.com/pcsetup It was really hard for me, for some reason. It was a long process for me. But basically install this program, open your firewall, so the 360 can get through. Then go to you 360/Media/Music then it will ask you if you've installed Media Connect. Say yes, and the 360 will try to connect to your PC. Good luck it took me about 13 tries. The ports I was told to open up was as follows:
Port/Name/Protocol
2869/Upnp Framework/TCP
1900/Upnp Framework/UDP
10284/Windows Media Connect/UDP
10283/Windows Media Connect/UDP
10282/Windows Media Connect/UDP
10281/Windows Media Connect/UDP
10280/Windows Media Connect/UDP
10243/Windows Media Connect/TCP
Hope you get it working. If all else fails call 1-800-4-MYXBOX
