You should have your set calibrated, not for just for burn-in, but so that you have the proper colors displayed.
Burn-in is a little overexaggerated. Here are the rules:
1.) Be careful during your first few hundred hours. Just like when you buy a new vehicle, the set needs to be run a little. It is most susceptible damage during it's initial few hours. So no static image and lots of varied viewing material.
2.) Avoid static images. This is true for most displays. It doesn't mean you can't pause a movie...it means don't abuse your set with hours and hours and hours of the same image. Common sense, if there is such a thing, should be applied.
3.) Vary your viewing material. Don't watch 2:35:1 DVDs or CNN for 100 hours straight. Run some DVD, some TV, some X-box, or whatever. Also, try to use the whole screen when watching TV.
4.) Don't panic if you see image retention. You can run an all white screen or simply changing your viewing material should clean it up. Image retention is temporary but is an indication that you aren't using your set properly.
5.) Get your set calibrated. High brightness and contrast settings not only cause image retention, it produces inaccurate colors.
You can damage other display devices that way for far less money.
