Originally Posted by ron12n
Actually, no.
What throws people off are the misnomers 'brightness' and 'contrast'. To
clarify things for yourself, think of brightness as 'Black level' and of
contrast as 'White level'. which is what they really are. Turning black
level up does not materially make whites brighter. Turning white level
up does not materially make blacks brighter.
The purpose of break in is to evenly excite the phosphors at low levels.
At a given white level setting, reducing black level increases contrast,
which is not what you want for break in.
The advice given earlier, to run break in at less than 50% contrast
setting is reasonable. But, I would leave the brightness setting as is.
-- Ron
Actually, no.
-- Ron
Ok, let's go to the basics, which is a good thing to do actually, because when the basics are covered, little space remains for misunderstanding :-)
What's brightness? Brightness is an intensity of the energy output of a visible light source. To put is simpler - it's an amount of light emitted by every pixel of the display, relatively to it's present state of excitement. Not that simpler, er? :-) Example then. Let's say we have a picture on a display. It has a logo of 30% of black on the background of, say, 70% of black. The difference of brightness (or the energy output) is 40%, which creates a slight possibility of developing burn-in over an extended period of time. Now, let's turn up brightness of the screen by 20%. What we'll have is a logo that is 10% black and a background that is 50% black. The difference is still 40%, the possibility of burn-in is the same, but a possibility of image retention (which is really an alltogether different thing) increases significantly.
What's contrast? It's the difference between the lightest and darkest areas on a display screen. The same situation: 30% logo and 70% background. Let's turn up contrast by 20% and we'll get a 20% of black logo and 80% of black backgroung. The difference is now 60% instead of 40, which dramatically increases the possibility of ineven ageing of phosphors, especially on a brand-new plasma (and a possibility of IR as well).
So, the point is - it's better to turn down the contrast during first 200 hours, and to keep brightness at reasonable levels, but if the image is too dark, there is no harm of increasing the level of brightness by 10-15%. And yes, the only reason of breaking in plasmas is to age fresh and fragile phosphors evenly and thus prevent burn-in. There's really no other reason IMHO.
. All
