I am getting a shimmer/waver in the bottom and top of my TV when setting the 360 to output in 1080i. I DO NOT get the shimmer/waver if the 360 is set to output 480p.
I have the 360 hooked up via component input to a Panasonic SA-HE100 receiver which then outputs component to a direct view Samsung TSL2793HF 27 inch HDTV.
If I plug the 360 directly into the TV then the shimmer doesn't appear. This leads me to believe one of the following...
1. The receiver is messing up the 1080i signal
2. The component cable from the receiver to the TV doesn't like the 1080i signal
3. There is electrical interference on the component cable from the receiver to the TV as all my cables (speaker wire, power, component) pass through a two inch hole in the back of my AV cabinet.
Does anyone have any suggestions or experience with this type of distortion?
