Originally Posted by
Landlubber
That said, I understand what holl_ands means when he says that tvfool "assumes" an omnidirectional antenna. To me, that has nothing to do with performance (how well it receives)
In terms of directivity(and a true Omnidirectional antenna which has none), certianly.
An Omnidirectional(or any) receive antenna has performance characteristics(such as gain) which are not modelled by TV fool, most signal "predictions"(such as what FCC does) are based on certian performance charactieristics of receive antennas used, that's all I was saying.
I only brought it up because it was not "exactly" clear to me whether or not he was refering to transmit antenna(which *is* modeled whether it's omnidirectional or directional) or receive antenna, I assumed he meant receive antenna but wasn't sure ....
.... only that tvfool will tell you what signals the location in question is capable of receiving, regardless of direction.
Yes, certianly ....
Landlubber
I also understand that there is a nearby signal on Channel 64 (4.2 miles away, at 250 degrees from true north) that may be interfering with a weaker, more distant signal on Channel 66 (50 miles away, 285 degrees from true north). So if I rotate my antenna a few degrees to the north, I
might be able to reduce the interference from the signal from KSGA (Channel 64) that may be keeping us from receiving KCOP (Channel 13.1/66).
I wonder what a polar plot for the RS 15-2187 Looks like? Specs on it on radio shack website indicate that whatever sort of antenna it actually is, it is apparently inside a radome ... and the RS specs show 1/2 power beamwidth on UHF is 60 degrees, which means it's directivity is not very good, and a station 30 degrees(1/2 of the 1/2 power beamwidth, which would extend 30 degrees on each "side" of where antenna is aimed) from direction antenna is aimed should only be rejected by about 3db (1/2 power) ... so with antenna aimed around 60degrees or a little more "away" from KSGP, it's possible you may perhaps(just a wild guess really) be getting around say, 10db or so rejection of KSGP-LP signal with your antenna aimed as it is, although that should really be enough(actually, No rejection of it should really be enough), I'd think.
Another "interesting" spec on 15-2187 on RS website shows average Front back ratio of 17db on UHF .... If anywhere near being true, that's actually pretty good, as usually with directional antennas(such as yagis), you have bigger nulls "off the side" of antenna than off the back ....
Keep in mind, KSGP-LP is a analog, Low power station. If the predictions from TVfool were absolutely "correct", based on FCC tests of various, recent DTV receivers this really shouldn't be a interference issue(even with use of a omnidirectional receive antenna) , as the predicted signal difference of 20db more undesired signal from KSGP-LP 64 than the desired KCOP-DT 66 signal is less difference than the worst performing receiver FCC tested these channel relationships for, and signifcantly less than the best performing receiver, for which the KSGP signal could be approximetely 29db stronger and reception of KCOP-DT could still be acheived ....
HOWEVER, the tvfool dbm values are predictions which are based on F(99,99) curves, and it very well may be the case that the signals you're actually getting may be significantly stronger than the predictions in dBm show, which will of course be even stronger with the gain added by your antenna/amp.
Of the receivers FCC tested for interference rejection given a desired signal level of -68dbm(the closest "in the ballpark" figure to your TVfool predicted KCOP-DT 66 signal of -63dbm via a "zip code" plot), The *worst* receiver tested was able to achieve DTV reception with a 2nd adjacent(N +2 signal) 28db stronger -- that should hopefully be pretty much be a "worse case" scenerio, and the best performing receiver on this test could withstand a N+2 signal 50db stronger than the desired signal+still acheive reception, the median of all receivers tested was a -41db D/U ratio ....
While KTTV-DT 65 (-57.2dbm) is predicted to be 6db stronger by TVfool(and these are only predictions, keep in mind), at signal levels for the desired signal of -53dbm, Most receivers tested by FCC, as one would expect performed worse in interference rejection tests with a 1st adjacent channel interfereing signal. The best performing receiver tested acheived reception of the desired signal with the desired signal as much as 40db weaker than the lower first adjacent channel(N-1) - 9db "worse" than the best receiver for the 2nd adjacent channel (N-2) tests -- and the median of all receivers was a -41.5db D/U ratio (almost exactly the same as N -2 test) ... But, the worst receivers did perform significantly better(by about 7db than N-2 tests) ..
Now, if the signal levels are actually signficantly higher than Tvfool predictions(lets say about 20db higher at receiver input), as you might predict, the receivers selectivity becomes worse per the FCC tests. With the desireed signal at -28dBm for instance, the receivers tested all had D/U's of about -26db for lower 2nd adjacent channel interference, and D/U's of about -21db for lower 1st adjacent channel interference ... Meaning the interfering signal caused DTV reception of desired signal to drop below threshold at these higher signal levels if the desired signal was at or more than 21db weaker than a 1st lower adjacent channel signal, or 26db(or more) weaker than a 2nd lower adjacent channel signal. *IF* however this was the case, then I would expect your KTTV-DT 65 signal to be non-receivable or have reception related "glitches" as well as KCOP-DT 66 ....
And, generally speaking, even though it is predicted as 6db stronger than KCOP-DT, Assuming you are getting good reception of KTTV-DT(digital) on 65, I'm skeptical concerning interference from KSGP-LP being the issue of concern, here(even if you were using a omnidirectional antenna, although that might cut things pretty close depending upon what the deired signal level actually is), and you certianly shouldn't need 55db less signal from KSGP-LP than KCOP-DT.
If there is a "interference" type issue involved, (rather than something else such as multipath or weak signals if the amp isn't working/isn't being powered properly/etc - note - in most cases, if a amplifier is unpowered, the unpowered circuitry in the amp will attenuate signals *greatly*, much much more than if the antenna wasn't amplified) ..... If anything, I'd suspect it may be more likely to involve the tuner/amp being overloaded(because your using an amp where there are some fairly strong signals around) .... I don't know anything about the real "specs" of the amp in that RS antenna, just based on what I do know (10db gain) if your going to use an amp, that would be the sort of "specs" you'd probably want in your sitatuation.(although, actually, you really shouldn't need a amp at all given the predicted signal levels involved, unless you need it for distrubution to various devices) ... But generally speaking, High power station KVCR(analog+digital) would probably be the biggest concern (unless perhaps there may be very nearby FM stations or other sources of RF not on TV band frequencies which could still overload things and cause IMD (intermodulation distortion) .....
I am still not clear on how to apply the chickenwire screen solution. Do I surround the antenna (with as large a radius as possible)? Or do I only erect it as a "shield", leaving an opening on the northwest quadrant to accommodate the signals from Mt. Wilson? For the record, my antenna is facing WNW, approximately 12 feet from the west, gable end of our house .....
My guess is going that route may involve quite a bit of experiementation(which may or may not yield any positive results) ... But basically, If you want to increase rejection of KSGP-lP, seems to me you would want to put the screen generally Southwest of the antenna, and you wouldn't want it between the antenna+Mt Wilson .... - As holl_ands said, perhaps in the attic would work ....
Or is there a third option?
If I were you, FWIW, I might consider trying an unamplfied antenna that offers better performance(especially better directivity) than the antenna you are using, then adding an amp later if necessary or desired ....
Although, OTOH, of course, as you've already noted, KCOP-DT will be moving to ch 13 in 14 months, so you might not want to put too much "effort" into it(and if you do you don't want to "concentrate" only on UHF, as you'll want to make sure your Hi-VHF reception remains good), as chances are very good that if you receive good analog reception on Hi-VHF(ch 7-13) as you've reported, the same will be true for the digitals, including KCOP-DT 13 ....
Again, as a layman I appreciate the many good things on this site.
I do hope I've explained the above "clearly enough" for it to be at least somewhat understandable(I'm doing my best, which is all I can do !), there are many factors which can effect OTA reception, and it can be very "complicated" to post about it and try to "guess" what may be causing any given reception problem in any given case, and even more complicated(and difficult) to post about it in "plain english" without writing a "book" so to speak ! .....
