AVS › AVS Forum › Video Components › DVD Players (Standard Def) › What players support 480i over DVI-D or HDMI?
What players support 480i over DVI-D or HDMI? - Page 8
post #211 of 238
Is the list up-to-date?
post #212 of 238
The following players do also output 480i/576i over HDMI according to their manuals:
JVC XV-N652S
JVC XV-N670B
Kenwood DVF-5400
Kenwood DVF-5500
LG DV390H
Onkyo DV-SP405
Onkyo DV-SP406
Pioneer DV-410V
post #213 of 238
JVC XV-N652S
JVC XV-N670B
Kenwood DVF-5400
Kenwood DVF-5500
LG DV390H
Onkyo DV-SP405
Onkyo DV-SP406
Pioneer DV-410V
Thanks, I updated the first post. Looks like 480i via HDMI may be more common nowadays especially if players share the same video chips.
larry
post #214 of 238
larry
The manuals for the Kenwood DVF-5400, DVF-5500, Onkyo DV-SP405, DV-SP406 and Pioneer DV-410V are looking pretty similar. I mean it seems all OSD options are the same. Could it be they are all the same player with a different case?
I just realized not even all Full HD sets do accept 480i/576i over HDMI... Looks like all LG and Samsung sets don't support 480i/576i over HDMI. Sharp and Sony seem to do it and Panasonic has no information about HDMI input formats in their manuals.
By the way I found another player which can output 480i/576i over HDMI according to the user manual:
Panasonic DVD-S54
post #215 of 238
I've been very impressed with Sony in this area.
post #216 of 238
May I ask why? I thought Sony current generation of DVD players don't offer 576i/480i support over HDMI.
post #217 of 238
Originally Posted by greeno View Post
LG DN898 via HDMI (480i, 480p, 720p, 1080i (1080p not tested) clips BTB and WTW.
Philips 59xx via HDMI also clips BTB and WTW.
Note: BTB = blacker than black, WTW = whiter than white.
Anyone know if the Pioneer DV-410V clips BTB/WTW?
post #218 of 238
It clips either blacks or whites. I can't remember anymore. To get no clipping at all you have to apply a custom/hacked firmware.
post #219 of 238
I just checked my "new" (bought as refurb from overstock.com) Panasonic DMR-EZ485VK VHS/DVD recorder, and it can output 480i over HDMI from the DVD player. I got it for $190 shipped at overstock. Yeah, yeah, it's got bugs like most set top DVD recorder/DVR's, but it appears well built and the VHS deck appears better quality than most ~$100 VHS decks you can find now. It outputs 480i over HDMI from the ATSC/QAM tuner and even the VHS deck!
I bought it to make it easier to convert old analog cable VHS recordings to DVD for the wife.
I don't know if it clips BTB/WTW. What is the easiest/quickest way to check? Avia? DVE? Just look for missing bars in the gray scale pattern?
post #220 of 238
Avia does not contain BTB (not sure about WTW). Use DVE or GetGray (AVS member disc).
larry
post #221 of 238
I own three MediaTek MT1389-based players. Their brightness settings range from -20 to +20. Their contrast settings range from -16 to +16. After reading manuals to the Onkyo DV-CP706, the Onkyo DV-SP406 and the Onkyo DV-SP506, I notice their video adjustments include only switchable black level, brightness, and sharpness (no contrast, tint, croma level, or gamma). This makes me think these Onkyos do not use the MediaTek. Can anyone prove me right or wrong?
post #222 of 238
With my Panasonic 50X1 being 720P and myself having a collection of standard DVDs coming out of the one for a fin tub would it make any sense to purchase anything other than a entry model? I'm not sure what is available at this time.
The standard DVD may well be dead but, I'm not interested in replacing mine w/blueray.
So, I'd like a DVD that will take advantage of a mail order HDMI cable w/o providing me more than my needs require. I wish to take advantage of what the panny offers through an equal quality entry level DVD.
I've tried some research here however, the volume of material is a tad overwhelming and for the most part geared to the higher end products.
Thanks...
post #223 of 238
I would like to say Pioneer Elite 79avi and Pioneer Elite 59avi both are good. I Like to favour a bit more to the Elite79.I think no one can exceed the Elite79's video quality. The Elite79 will play amazing anything you through at it without noise.
post #224 of 238
Hi..
Good information regarding 480i players over DVI-D...
post #225 of 238
Thanks for your sharing, But I still use Sony DVP-NS975V
post #226 of 238
hi there....
I have a Pioneer Dv-400V-K and am going HDMI out into the DVI-D port of a panasonic projector. The pioneer does not support the type of cable connection and will only allow me a 480P output on the projector. The projector, a PT-DW5100U, is capable of supporting 1080P input.....
post #227 of 238
Originally Posted by Robonaut View Post
Hidef players:
Sony BDP-S1
Pioneer BDP-HD1
Toshiba HD-A2
[I added list here and left the other entries for "historical purposes". The OP or myself can edit the list when needed. Post additions below....larry]
The Insignia NSBRDVD with netflix streaming outputs 480i via HDMI according to the manual. That is interesting with the Netflix stream. I wonder if this would make a decent straight DVD/Netflix player for the base level scalar in my Onkyo 886?
post #228 of 238
I have a Toshiba A-2 HD DVD player that I see can output 480i over HDMI. I would like to connect it to my new Denon 2310CI receiver with the Anchor Bay chip to be able to upconvert SD DVDs to 1080p/24Hz.
Has anyone used a combo similar to this? I know it's the same chip as used in the DVDO Edge, but with many functions not activated. Just curious.
thanks!
ej
post #229 of 238
Originally Posted by lindseyparker View Post
I would like to say Pioneer Elite 79avi and Pioneer Elite 59avi both are good. I Like to favour a bit more to the Elite79.I think no one can exceed the Elite79’s video quality. The Elite79 will play amazing anything you through at it without noise.
Too bad the 79AVi failed most of the Secrets benchmark tests
Was there a firmware fix?
I have 59AVi which scored much better, but won't handshake with my Anthem
post #230 of 238
Not sure if this is the right place to ask this, but I am having trouble with my dvd player not keeping up with bit rates... Anyone have a suggestion for the dvd player that can run the highest bit rate on the market?
post #231 of 238
Um, isn't the point of 480i over HDMI so that you can avoid the player doing any processing? Consequently, you can just ignore anything about cadence detection and deinterlacing performance. Just try to find a player that's responsive, has good playback controls, and bitstreams all audio formats over HDMI.
post #232 of 238
Hey, it seems like the Toshiba BDX2150 has an option to configure HDMI for 480i. At least, according to the manual:
http://cdgenp01.csd.toshiba.com/cont...BDX21KU_OM.pdf
Can anyone confirm this about it or other Toshiba players in that series?
post #233 of 238
I got a slightly older Toshiba player (BDX1200) that does have a 480i output mode. My video processor confirmed that it was indeed 480i.
At the same time, I ordered a JVC XV-N680B DVD player. I also confirmed that I was able to set its output to 480i. Since this player has been discontinued, I was only able to find one that had a multi-region hack. When I tried a PAL disc, the output was still limited to NTSC resolution - I could not get it to output 525i @ 50 fps, for instance.
post #234 of 238
Which is the best DVD player with 480i over HDMI?
Its only purpose going to be DVD transport. I will run 480i over HDMI(preferred 4:2:2) into algolith mosquito hdmi video noise reducer then Crystalio II video processor to de-interlace and upscale to 1080p via its Gennum VXP.
Below is what I am looking for
480i over HDMI (YUV4:2:2)
Pal/NTSC playback ( conversion is NOT needed)
All region playback
CUE free
Pioneer DV-420 and Oppo DV-980 seems to fit above description. I can buy the pioneer brand new still. Do I really need oppo over pioneer?
post #235 of 238
Does it have to be a DVD player? Oppo BDP-83 is good and plays everything.
post #236 of 238
Algolith doesnt pass 1080p. Thats why it has to be a dvd player.
post #237 of 238
post #238 of 238
983 will not do 480i over hdmi. Only 980 does.
  Back to Forum: DVD Players (Standard Def)
