The Basics
HDTV can be recorded in these ways:
· D-VHS
· HDTV Tuner PC Card
· Firewire Source to PC, Mac
· USB Source to PC, Mac
· HDTV DVR from Cable, DBS, OTA
· Blu-ray burner
· HD Camcorder
....from five potential sources:
· Digital Television (DTV)
· Direct Broadcast Satellite (DBS)
· Cable
· C/Ku Band Satellite
· Live to video
D-VHS
Digital VHS is capable of recording and playing back the full 19+ Mbps data stream of ATSC HDTV broadcasts, including Dolby Digital 5.1 audio. There are different varieties of D-VHS decks, but all are essentially ‘bit buckets’, capable of recording HDTV and playing it back identically to the original broadcast. Typcially, an outboard source provided the HDTV signal via Firewire to the D-VHS deck, with only one D-VHS unit having a built-in DTV tuner. This approach also allows for HDTV copies using Firewire recording from D-VHS to D-VHS, D-Theater (prerecorded movies) excepted.
· Mitsubishi HS-HD2000U $749 ($549)
· Mitsubishi HS-HD1100U $549 ($395)
· JVC HM-DH40000 $999 ($537, D-Theater, component video)
· Marantz MV 8300 $1599 ($999, D-Theater, component video)
· JVC SR-VD400US (Pro D-Theater)
· JVC SR-VDA300US (Pro D-Theater Master Deck)
· JVC HM-DH5U $799 (HDMI, D-Theater)
· JVC HM-DT100U $1499 (HDMI, DTV tuner, D-Theater)
· Marantz MV8300 $1099 (Same as JVC HM-DH40000)
· Panasonic PV-HD1000
· JVC HM-DH30000
Firewire sources for HDTV Recording
· Motorola, Scientific Atlanta, Pace - Digital Cable STB's
· 169time
After market modification for adding Firewire HD output to specific STB’s.
http://www.169time.com/
Discontinued
· Mitsubishi HD6000 (DTV & Cable)
· MIT MDR-200 (DTV)
· Specific Mitsubishi integrated HDTV’s (DTV)
· Mitsubishi HDTV's compatable and equipped with the Promise Module (DTV)
· Specific Hitachi integrated HDTV’s (DTV)
· Samsung SIR-T165 (DTV)
· Key Digital KD-FIRE1080P HD Hanna $2999
http://www.keydigital.com/lprodi.asp?Ic=KDFIRE1080P
· Pioneer Plasma HDTV w/ Media Receiver CableCARD
· Various Firewire equipped HDTV's
· Panasonic TU-DST50 & TU-DST51 (DTV)
· Sony DHG-M55CV (Cablevision, still available)
· Mitsubishi HD5000 (DTV)
· LG LST3410a
NOTE: Not all Firewire equipped HDTV's can output HDTV via Firewire. See the manufacturers specifications for details.
Discontinued 8VSB HD Source:
· Dish 5000 w/HD Modulator
USB sources for HDTV Recording
· Nextcom R5000-HD
After market modification for adding USB HD output to specific STB’s.
http://www.nextcomwireless.com/r5000/home.htm
· USB DTV Tuners
Capable of DTV reception, recording and playback. For in depth discussion of this aspect of HDTV recording, please see the AVS HTPC Forum.
http://www.avsforum.com/avs-vb/forumdisplay.php?f=26
HDTV Tuner PC / Mac Cards
Firewire Source to Windows & Vista PC
For in depth discussion of this aspect of HDTV recording, please see DVHSTool and other topics in the HDTV Recorders Forum.
PC recording of HDTV is made possible by Microsoft Windows XP & Vista native support for IEEE1394. The PC can be used as both a storage/ retreival device and a playback device. The PC's peripherals (hard drive, DVD drive) are used to store the HDTV signal that comes from compatible sources. Used as a retreival device the stored HDTV signal is played back through the IEEE1394 to a display device or other storage / communication device. Used as a playback device, various hardware and software HDTV signal decoders can be used to present HDTV video and audio for viewing.
To use the IEEE1394 interface in WinXP, specific support of the partiular model of unit with the IEEE1394 port is required. That is, the presence of a IEEE1394 port doesn't imply compatibility with Windows XP. Various drivers and applications software are required and available to use the JVC and Mitsubishi DVHS decks with Windows XP. For example, even though one "OTA only" model of the Samsung HDTV has IEEE1394, it cannot be used with Windows XP since there are no mating drivers. The 169time equipped DTC100 can be used with Windows XP.
My sincere thanks to AVS member h2ofun for providing this information.
Firewire Source to Apple Mac
A FireWire equipped Apple Mac running MacOS X 10.4 Tiger can function as an emulated DVHS deck for both recording and playback of OTA HD broadcasts. To accomplish this you will need the demo application VirtualDVHS2 which is included with Apple's Firewire SDK 20. VirtualDVHS2 should work with a variety of devices including most Mitsubishi HDTV's, the Samsung SIR-T165 STB, Mitsubishi HD-2000U and JVC DVHS decks. The FireWire equipped devices control all recording and timer functionality and the Mac simply acts as a DVHS deck. The improved GUI of VirtualDVHS2 simulates the front panel of a DVHS deck including record and playback buttons and a counter. Please note that the VirtualDVHS2 demo is really a refinement of a proof of concept rather than a supported Apple application although some forum members have had good results. Source code is also available so some enterprising developer may be able to wrap a polished GUI around this and ship a commercial product.
An AVS member has developed software, iRecord, using Apple's latest AVCVideoServices framework to record 5C copy-freely content from Motorola and S-A STBs equipped with FireWire. The software allows for timed-recordings and tuning channels.
The FireWire SDK 20 which includes VirtualDVHS2, source code, and other programs such as AVCVideoCap and DVHSCap can be freely downloaded from Apple developer site at the URL below. Be sure to read the readme included with VirtualDVHS2 for configuration info.
FireWire SDK 20
My sincere thanks to AVS members rcliff and jsb_hburg for providing this information.
HDTV PVR
Cable
· Scientific Atlanta
· Motorola
· Pace
· TiVo HD
Discontinued
Sony DHG-HDD 250 or 500
DBS
· Dish Network HD DVR MPEG4 compatable
ViP 612
ViP 622
ViP 722
· DirecTV HD DVR MPEG4 compatable
H20
HR21
OTA
· TiVo HD
Discontinued
HDTV Camcorder
For in depth discussion of this aspect of HDTV recording, please see the AVS Camcorder Forum.
http://www.avsforum.com/avs-vb/forumdisplay.php?f=161
Blu-ray Burner
Coming soon.
· D-VHS
· Blu-ray burner
· HD Camcorder
· Cable
· Live to video
D-VHS
· JVC HM-DH30000
· 169time
Discontinued
· MIT MDR-200 (DTV)
· LG LST3410a
· Nextcom R5000-HD
· USB DTV Tuners
FireWire SDK 20
HDTV PVR
Cable
· Motorola
· Pace
· TiVo HD
Discontinued
DBS
ViP 612
ViP 622
ViP 722
H20
HR21
OTA
· TiVo HD
Discontinued
HDTV Camcorder
Blu-ray Burner
Coming soon.
