Originally Posted by mizedog
I've got my Viewsonic Pro 8100 mounted overhead, and shooting the Do Able screen. The screen is just sitting nearly vertical on top of the old speakers I'm using. However, I bought four plinth blocks and some 1.25" diameter poplar dowell rod to make some stand-off mounts for the screen. The plinth blocks are MDF with an ogee edge pressed into three sides. I drilled wholes using the drill press on my Shopsmith and cut notches in the side of the dowels with my chop saw. The notches/grooves on the lower mounts are only about 1/8-1/4 inch deep. The ones in the top dowels are 3/4" deep. This will allow the mounts to be screwed to the wall, push the screen out about 3" from the wall to clear the crawl space door. Just like a window pain installs by sliding the top edge in and up, then resting is down in the track, the mounts will do the same and only intrude on the screen's front surface 1/4" at most.
So far, though, the WAF is high for this screen. I'll trim the ends off to a proper 19:9 ratio which should give me about 98" diagonally. Not bad for a 13'x17' room.
It's easy for me to lift off and place on the floor leaning against the wall. This allows me to get to the crawl space easily.
Hi, I have the Pro8100 also and as curious about how you like it on this screen? Thanx
I had a different pj prior and have a painted BOC screen of n 7.8 and now want a brighter image so I can still use the eco mode.
I ended up buying another one! Take a blanket guys; see another note below).
about the frame. I am sure velvet will look nice but I was not sure how will I mount the frame without damaging the cloth. I decided to paint it with flat black paint rather than velvet. I found a pre-painted 1"x2.5" mdf trim in the moulding section. This saved me the priming and the black came out really nice in one coat.
