Originally Posted by twitchee3
I strongly suspicion that FIOS has almost all digital channels, so that means you will only be able to get the analog channels by hooking the coax straight to the box. Other than that, the box can only display one channel at a time, no matter how many A/V outputs the box has.
In the No VA area it's 318 to 21 the number of digital vs. analog stations.
Most cable cos will switch to this ratio and after 2009, you'll be hard pressed to find any analog channels. Granted a number of those digital channels might be in the clear.
S-video is just that - video only - you have to use the audio connection with it to get audio.
