I lucked up and got it for next to nothing 10 years ago and it was having the typical convergence problems and suffering from dirty lenses. I cleaned all the pots and everything started working like a champ.
Unfortunately, I have recently moved into a new house and no longer have room to set up the set. I am considering selling the set. I have everything accept one of the support brackets that goes on the back of the set. Where the screen brackets slide into. I have it jury rigged with a bolt, works fairly well the screen sits a little low on one side; with enough time a creativity I am sure that can be corrected. All the screen brackets are there and I have the screen too. The screen has a few scratches in it but I would say over all its in good condition. I do not have the remote. I believe this unit was used very little before i had it. I used it regularly for about 2 years and then really only used it to watch movies or when company came over. I wanted to set it up in my basement and I thought it was going to work but I am 1" short of it clearing the ceiling.
I am much like all of you in that I am very emotional over this TV. I found it very easy and fun to work on. However, I think at this point I need to find a new home for this set. I live in Dallas, NC. Any ideas on what a set like this will fetch in todays market? I don't believe there are very many of these things left in the world. The money is not as important as making sure the unit goes to a good home. Any advice would be great.
Ed
Ed
