I am relatively new to the home theatre game, and now find myself plunging head first. Long story short is I will have the following setup:
Reciever: Onkyo Tx-NR609
Front LR: Monitor 70
Center: CS2
Surrounds: Monitor 60
Sub: BIC F12
My question or concern is using the tx-NR609 to power the monitor 60 and 70.
Will the Tx-NR609 be able to appropriately power the speakers in this arrangement? My untrained eye believes it will be adequate. I have included the specs from onkyo below.
Also what is the recommended placement of the floorstanding surrounds in a 5.1 configuration. I have read that the tweeter should be above ear level, however with floorstanding i don't see that as possible. Any suggestions?
Power Output
Front L/R
110 W + 110 W (8 ohms, 20 Hz-20 kHz,
0.08%, 2 channels driven, FTC)
130 W + 130 W (6 ohms, 1 kHz, 0.1%,
Center
Surround L/R
Surround Back L/R
Dynamic Power
250 W (3 ohms, 1 ch)
220 W (4 ohms, 1 ch)
130 W (8 ohms, 1 ch)
THD (Total Harmonic Distortion)
0.08% (20 Hz-20 kHz, Half power)
Damping Factor
60 (Front, 1 kHz, 8 ohms)
Input Sensitivity and Impedance
200 mV/47 k-ohms (Line)
2.5mV/47 k-ohms (Phono MM)
Rated RCA Output Level and Impedance
200 mV/2.2 k-ohms (Pre out)
Maximum RCA Output Level and Impedance
4.6 V/470 ohms (Pre out)
Phono Overload
70 mV (MM, 1 kHz, 0.5%)
Frequency Response
5 Hz-100 kHz/+1 dB, -3 dB (Direct Mode)
Tone Control
±10 dB, 50 Hz (Bass)
±10 dB, 20 kHz (Treble)
Signal-to-Noise Ratio
106 dB (Line, IHF-A)
80 dB (Phono MM, IHF-A)
Speaker Impedance
4 ohms–16 ohms or 6 ohms-16 ohms
Power Supply
AC 120 V~, 60 Hz
Power Consumption
6.3 A
Dimensions (W x H x D)
17 1/8" x 6 7/8" x 14 15/16" (435 x 174 x 379 mm)
Weight
26.9 lbs (12.2 kg)
Thanks for your inputs.
