Originally Posted by
rebuy
When you Bi-Amp you have to use Two Amps, thus the term Bi-Amp.
What you're probably thinking is Bi-Wiring, where you run a 2 sets of wires to one speaker from the same receiver. One for lows and one for highs. A lot of people think it's a waste of time and the results get mixed reviews.
Here's the problem I see with what you want to do. First, the receiver you have is weak when switched to 5.1 and even weaker when asked to play 7.1.
When you bi-wire your speakers from the same receiver you have to use another set of output channels to make the second connection to the same speaker. When you do this, it puts additional strain on the receivers amp section and causes a power drop. It might make your receivers power drop so low that it puts your receiver in danger of "clipping" when trying to turn up the volume. I will use my receiver as an example of a power drop, look at the numbers here.
My receiver is rated at 100 WPC, is high current with discreet amps.
AV Receiver Reviews
Onkyo TX-SR608 A/V Receiver HT Labs Measures
HT Labs Measures
Five channels driven continuously into 8-ohm loads:
0.1% distortion at 82.3 watts
1% distortion at 84.7 watts
Seven channels driven continuously into 8-ohm loads:
0.1% distortion at 30.9 watts
1% distortion at 40.1 watts
You can see even with this amp section, I get a 17% power loss in the 5.1 mode and a 60 to 70% drop in 7.1. I might be wrong but I think the Onkyo amps are more heavy duty than the one found in normal Pioneer units.
Because of the power drop and the danger of clipping the amps which in turn burns up a speaker, I would not use this receiver in a 7.1 set up.
You want plenty of good clean power for your speakers and bi-wiring might or might not make an audible difference. I don't think this is your receiver but look at these numbers.
Pioneer VSX-1120 A/V Receiver HT Labs Measures
HT Labs Measures
0.1% distortion at 47.0 watts
1% distortion at 52.3 watts
0.1% distortion at 38.9 watts
1% distortion at 47.1 watts
I would just run one set of wire to the Polks and be happy.
I would not bi-wire due to the power drop.
But that's just me, your results may vary.
I hope this helps you...
