Originally Posted by Jinjuku
This thread should be a good read for you. It was a new member looking at an Integra and Anthem. Sales rep actually brought receivers out to his house and ran the correction routine. He went with the $2K Integra vs the $5K Arcam.
True, but your comparing the Integra 80.3 with XT32 against ARC. I am comparing XT to ARC.
Considering he said he couldnt tell the difference between the ARC and XT32 models, it makes the MRX-300 even more enticing since I will be using it as a processor so the wattage differences between them dont matter....
The XT model is more than likely what I will go with as I just cant pony up the 1k for the MRX300 model as easy as the NR709's cost of 500.....
We in a nutshell, AFAIC, XT gets the mains right above the 80-100Hz mark. After around 400Hz the room quickly diminishes and you are now talking about on/off axis response which you don't EQ for. It's just the subwoofer portion that a good amount of people that have measured and found wanting
So XT only EQ's the mains down to 80hz? That sucks as my fronts can go quite a bit lower than 80hz..... Normally 2EQ sets them to full range and I run them as such. The Center I am running at 60 hz right now.
Just got the LSi F/X mounted and havent re-run 2EQ at all since we moved here, so hopefully I will do that tomorrow or next Sunday....
