So I've been reading a searching for suitable 750-1000 watts Class AB amps with low THD and high SNR. I've been looking at a lot of the Class D amps on the market and have realized that there are literally hundreds of low cost Class D pro-amps out there. The one thing that leads me to doubt, is the relatively high THD and "noise". I looked at the specs for a RMX 4050HD from QSC and have noticed that the higher fidelity and higher quality Class Ds are fairly expensive as well ($1,600.00 and up). Some are over $2,200.00.
My Onkyo NR3009 has a rated RCA pre-out of 1V/470 ohms with a maximum output of 5.5V/470 ohms. Most of the Pro amps have an input sensitivity of 1.2 - 1.4 V at around 10K ohms unbalanced. This is problematic to say the least. I know that the XPA-1 is a beast and is rated for 500W RMS and will power my speakers to no end., however, two of these bad boys will cost me ~$2,000. I have also been considering a second XPA-2 and running them in bridged mode. That should give me over 500W RMS per speaker.
Are there any high quality, high power amps out there (preferably Class AB) that won't break my budget. I can't find any. Just curious.
Advice/suggestions are welcome folks.
I love this forum.
