Originally Posted by jdkoola
I have the Diamond 8.2 in a 2-channel system. They sound absolutely fantastic for well recorded female vocals (Diana Krall, Holly Cole, Norah Jones, etc.), but the sound is a little muddier in more complex rock tunes. That is to say that I'm blown away when I listen to Holly Cole but not so much when I'm listening to rock.
I'm driving them with a HK 335. Is this a situation where I need more power, or is this just a limitation of this line?
I don't know.....hard to say.
It may be a result of both things you mentioned.
The Diamond series certainly has it's limitations. You may want to try auditioning the Diamond 8.3 and Diamond 8.4 to see if they do a better job with rock. I can tell you the Evolution 30 and 40 have no problem with complicated Rock music, and the Opus 2 are superb.
I also tend to lean towards the the mindset that a Reciever such as the HK 335 can not and will not do full justice to a set of speakers and drive them to their full capabilities.
You can always try some seperate amp and see if you hear a difference.
Probably the best purchases I ever made in Audio.
