Hey ice, first the breaking and biwire questions. Yes, they break in over 100-200 hours of use. They will open up some. As for biwiring, I think it's terrible. Check this out : http://www.sonicdesign.se/biwire.html
The phasing issues introduced produces that "airy treble" everyone goes ga-ga over. The problem is, not all music is supposed to sound that way! I found that things got much crisper and cleaner when I went back to single wiring, and even better with single wiring at lower gauge. The scientist in me has to say also that I noticed the audible artifact as such and became unhappy with biwiring after listening to a variety of music, and only then found the article to explain exactly what I was noticing.
I've noticed that satisfaction with the EVOs goes up with increasing power. It looks like you've got 75W/ch. I've got mine running off of a Yamaha HTR-5960, 110W/ch. But I can tell the difference at loud volumes if I run my receiver on the 6Ohm setting (which limits power delivery). So even 110W is not "saturating" the speakers with power. I'd be interested to see what the EVOs sound like on a couple of monoblocks at 200W.
With 2ch music cranked up they do sound pretty good - a lot is the limitation of my condo and the placement of my gear I'm sure. I've got concrete floors & ceilings (10') and the speakers are sorta in a corner... so I know I'm not doing full justice on that front.
Just need to replace that horrid center channel still!
