George, thanks for the comments. I welcome any suggestions as this is a work-in-progress. And, since I'm doing it myself, it does not cost too much to change things as I go
Originally Posted by
GeorgeIII
Steve
You know the more you think about this the harder a decision is. Now I'm coming up with reasons for one of the others because I really like nice woodwork. What we are deciding on is the visual effect when entering the room with some or all of the lights on. If the theater is light controlled, then the woodwork will disappear when the lights are turned off. That said I like #5 or #7.
As far as the woodwork -- my wife and I really like it. It is more work (for me) but I want the room to have a nice crisp and modern appearance when people walk in (with the lights on). Once the lights go off, yes the "wood" effect is minimized -- but hopefully if I do it right, the low lighting will take over from there (and the movie too LOL!).
I plan to have 6 lighting zones in the room. Each column will have a light shooting up at the angled vault (just for effect -- wife did not want wall sconces), rope lighting around the coffered ceiling, fiber stars inside or above (have not decided yet) the coffered ceiling and finally 9 can lights (3 front, 3 middle and 3 rear) each row on a separate zone. So making the lighting "just right" should be easy to do.
GeorgeIII
I have a real hang up with the light tan fabric, it would be great with the lights on but I'd be afraid it would be too visible even in a darkened room. Personally I'd go with any option that didn't use the tan fabric.
Honestly, I feel the same way. The bummer part is GOM 701 (or GOM Vertical Surface Solids 2402) does not come in a dark brown color that is acoustically transparent. All the walls will be a chocolate brown (GOM Anchorage 2335 - 2083 Coffee Bean). The brown anchorage is not AT so it cannot be used for speakers. WAF will not allow black over the speakers.
If I could find a dark brown AT material to cover my speakers, I'd use it. But as of right now -- I have not been able to locate anything that would work.
If anyone knows a fabric that will work and is AC, PLEASE LET ME KNOW!
