Welcome to the real world. Unfortunately that is the way it is going to be at least for a while. The broadcasters are diluting the signal by cutting the bit rate so as to squeeze more channels into the pipeline. I get my network HDTV via OTA broadcasts received via an antenna. Over the air broadcasts are suposedly to have less pixelation than the signal received from the cable, but there is still plenty of pixelation. I wouldn't blame it on the cable company. It is probably the fault of the network. While watching the TN-LSU football game I noticed that the pixelation was especially bad. CBS is pretty bad sometines. In that particular instance you can probably blame CBS or maybe the cable company, but it won't do any good. It doesn't mean that there is anything wrong with the cable box. Theoretically the motion artifacts should be better when watching ABC or ESPN, FOX, etc since they are 720P instead of the 1080P that everyone else is broadcasting. Not all HDTV broadcasts are perfect. They tend to be better when there is less motion, and the camera is not panning. The broadcasts on HD Net tend to better in general. I think we are going to have to live with pixelation unless we watch D-VHS tapes or one of the high defination disc formats.
Larry Raulston
Larry Raulston
I'd encourage anybody who has a digial tuner in their HDTV to get an antenna and see how they don't need to pay anybody for the locals and get channel 7 too. Unless one lives in some really deep canyon, it's purr-dy easy to pick up everything but 20. The higher you are the easier 20 gets, mostly, seemingly. As easy as these local broadcasts are to get, how long before the cable kompany has to offer a package sans locals?
