Originally Posted by cavu
That's BS. There was a bug and I fell prey to it way back when. *SOMEWHERE* in this thread is the solution to making it all wake up properly. I don't remember exactly but I believe it was one of those hold these three buttons down while powering up and the entire projector goes back to default settings which allows it to operate and upgrade the firmware!!
I really think it is something worse I can't even get it to go green when it gets plugged in... It does nothing but what I explaind on previous post. But I don't get it not one bit. I went over both boards and can't find anything wrong.... They both look brand new just a lil hot spot under were the pink wire goes for the bulb buy the transformer.. and its not bad at all fuses are good I think I got a paper wate :-(
