Hi. I am seriously considering switching from DirecTV to Verizon FiOS TV. I live in Fairfax County, Virginia and FiOS TV will be available very, very soon.
My questions concern the installation and wiring.
My understanding is an ONT box will be installed by Verizon on the outside of my house. This ONT will have three (3) connections of type:
1) Coaxial (for FiOS TV),
2) RJ-45 100BaseT Ethernet (for FiOS internet),
3) Not sure, probably simply a regular phone type jack (for my phone service).
The coaxial connection is for the FiOS TV. If the installer runs an RG6 cable from the ONT to my attic (where my DirecTV multiswitch currently is), and replaces the multiswitch with something else (not sure what this would be?), I can use the exising RG6 cables (currently the outputs from the multiswitch) to distribute the FiOS TV signal to the new Verizon FiOS TV STB's and then to my TV's.
Is this correct?
If it is, can I still use my antenna for my local OTA digital channels? Right now, my antenna is in the attic connected to a RG6 cable that is connected to a splitter. Each output of the splitter is diplexed with an output of the mutiswitch. At each TV that I want to get my digital local OTA channels, I have another diplexer and connect each output of the diplexer to the antenna input and satellite input respectively of my current DirecTV STB. I would hope I could do something similar with the Verizon FiOS RG6 in the attic?
If I go with FiOS TV, I will also go with their internet service (15Mbs). I think this setup will be a lot simpler than the TV setup. All they need to do is run an ethernet cable from the ONT into the house and connect it to a wall jack (which they will install). From the wall jack, they will connect an ethernet cable that goes to a wireless router (provided by them). From the wireless router, I can connect my main PC to it using an ethernet cable. My other computers can connect wirelessly to the router using their existing wireless adapters (802.11g).
Is this all correct?
Is this correct?
