AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › NEC new plasma thread!!! - 42xr4, 50xr5, 61xr4
NEC new plasma thread!!! - 42xr4, 50xr5, 61xr4 - Page 155
post #4621 of 4642
Originally Posted by JG1 View Post
Looks every bit as sharp if not sharper then my NEC. This display definitely has the 3D pop going.
I couldn't be happier with it, and the price is right....I paid less then half of what I did for my NEC.
jg,
Have you seen other Pio Elites to compare with the 500M?
I have never been impresssed with the flat/soft Elite picture.
I have not seen the Pio reference monitors so I hope they are sharper than the previous models?
thx
bob
post #4622 of 4642
Ressurecting an old topic that hopefully someone can answer for me easily (and quickly):
I just got a new HTPc with an ATI 4550 based card with HDMI output. Previously I was getting near 1:1 pixel mapping through VGA connection, but now on HDMI and the new HTPC everything is messed up.
- By default, 1365x768 is not a resolution i can select in display resolutions in Win7
- If I go into "Signal" info in the NEC menu, it says it's
H. Freq = 33.8khz
V. Freq = 60.0hz
H + V polarity = positive
Memory = 94
Resolution = 1920x1080
This stays the same no matter what resolution i choose.
- I am getting quite a bit of underscan with about 1" around all the sides
- I've tried installing powerstrip with no luck, although I'm new to powerstrip so may have done something wrong
- I tried adding my own custom resolution of 1365x768 with these powerstrip timing values I found way earlier in the thread:
PowerStrip timing parameters:
1365x768=1365,51,50,60,768,4,4,12,72149,33
Generic timing details for 1365x768:
HFP=51 HSW=50 HBP=60 kHz=47 VFP=4 VSW=4 VBP=12 Hz=60
VESA detailed timing details:
PClk=72149.00 H.Active=1365 H.Blank=161 H.Offset=35 HSW=50 V.Active=768 V.Blank=20 V.Offset=4 VSW=4
Linux modeline parameters:
"1365x768" 72.149 1365 1416 1466 1526 768 772 776 788 +hsync +vsync
However, even when I "paste timings from clipboard" that into a custom resolution into powerstrip, the resoultion that gets configured is 1364x768, not 1365x768.
- Oddly, in the display profiles screen, my plasma is being detected as "Generic PnP Monitor" with max resolution of 1280x720 at 50hz". Not sure why it's not detecting it as the NEC 50XR5 like it used to on my old HTPC when connected through DVI. (no idea whether it should report somethign different, just watned to give more info in case it helps)
Any help would be appreciated! I'm crazy frustrated
post #4623 of 4642
I'm looking for spare parts for my PX-50XR5A I need a working x/y control board. It would be perfect to harvest this part from a plasma that died because of power supply, broken glass, or dead panel. The electronic control boards should still be in-tact. The boards are small and on the back of the panel.
Any idea where i could source spare parts for my unit online??
post #4624 of 4642
I realize this has come up before- but couldn't find it. I am hopeful that many of the old guard still can receive this thread Q?
My NEC 50 xr5 (2005)- twice in the last month as just turned it's self -OFF- during viewing. No extended hours-no high living room heat..... no other clicker - being used at that time. HDMI video-S/pdif audio. Using the comacst box. Audio stays on-w/ no issues.
No timers in either- gear active.-- at least i know of.
I just take the remote and _hit_on_. back to normal.
Anyone know _why_. What to do.
db
Do we
post #4625 of 4642
Some of us are still here, but unfortunately (for you), I have the same set from about the same timeframe, and have yet to experience what you are describing. Since it's possible what you're experiencing may happen to others in the future, including myself, please post back with what you find out and what you end up doing. Thanks.
post #4626 of 4642
I haven't had any issue with mine yet. I bought mine in Feb 06. Let us know what you find out. Good luck.
post #4627 of 4642
My 50XR4 did the same thing, except that it turned itself completely off. I brought it to an authorized NEC service center, and it ran fine for days--they couldn't find what was wrong. A few months later, it started doing the same thing again, and I brought it back. Again, they couldn't find what was wrong, but they suspected it was a bad capacitor somewhere in power supply (I'm afraid I don't have more details). I brought it home, and I haven't had any trouble since (knock on wood). That was over a year ago; the plasma's still going strong.
post #4628 of 4642
Originally Posted by Seerden6 View Post
Did Nec mention what they thought the problem could be? And how much it would be to fix? thanks.
Is your NEC stand ST2U still for sale. Houston, Texas.
post #4629 of 4642
I have one still in original unopened box. Wall mounted unit.
PM me if you're interested.
Powerdyne
NEC => Fujitsu => Panasonic
post #4630 of 4642
Yes, perhaps.
What is your best price?
post #4631 of 4642
XR5
does anyone know/or advise to replace #2 HDMI input?
One of my two HDMI inputs has been damaged. So i would like to fix it{i can live without it/just swap cable when watching cable to DVD}.
The plate screw is right next to it[as you can see] and the others are on top.
db
post #4632 of 4642
I'm not getting much Love here .
So I take it, there's not much of a value in replacing the HDMI port.
I was hoping to wait out until OLED 60' displays were ready.
SooL...
TX,
db
post #4633 of 4642
Hooked a Denon AVR 3311ci up to an NEC XR50 and can't get the HDMI to play nice. Below is a link to my question in the 3311 thread but thought I would ping the NEC thread and check if this is simply a limitation due to the age of the XR50 or user error.
http://www.avsforum.com/avs-vb/showt...5#post20202775
post #4634 of 4642
Don't have that AVR, but still have the XR5 and it's going great with no problems or issues, including the HDMI. I've fed/feeding it Onkyo and Pio Elite AVRs, Oppo Blu-Rays and DVD players, and various TiVos, all with no problem - all via HDMI.
Good luck, and hope you find a solution.
post #4635 of 4642
can someone please pm me the service menu code, my remote doesnt have the edit button. the bruzzi link is broken.
post #4636 of 4642
SooL...
TX,
db
Get an hdmi switcher 4x1
bob
post #4637 of 4642
Originally Posted by puppydg68 View Post
Hi guys 3 years 3 months my plasma has started to display a white banded pattern about the size of a belt 2 inches from the top of the screen, now a few weeks later i have 2 of these belt patterns about 2 inches below the first. Called NEC the wont' fix it under warranty so it's basically a throw-away.
I am selling the pedestal stand, fix the PX42 PX50 sized TV's. Would prefer to sell in Ontario, since this bugger is heavy.
NEC PX-ST2U Table Top Swivel Stand
I'm still looking for the parts to fix my plasma. I need for 50Xr5
9S890036 - Common Connection Board
9S890037 - Digital Board
If anyone has any suggestions where or how to find them.
post #4638 of 4642
Nearly seven years with my XR5 and still working great.
post #4639 of 4642
I'm about the same with my 42xr4!!! And it still looks pretty damn amazing. Every time I think I want to get something new or bigger, I just don't smile.gif I'm sure it's not as good looking as I think it is, but blu-ray disks look awesome on it.
post #4640 of 4642
My XR5 is going great as well. No need to upgrade and I think 3D is very over-rated!
post #4641 of 4642
7 years, and still a great picture with the XR5 in our family room. We just bought a VT65 for our bonus room and the XR5 more than holds it own....
post #4642 of 4642
Anyone remember offhand how much the XR5 weighs?
