AVS › AVS Forum › Display Devices › Display Calibration › Service Menu Access Codes : Official Request Thread
Service Menu Access Codes : Official Request Thread - Page 38
post #1111 of 1344
looking for the access codes for a 54vt25. thanks
post #1112 of 1344
Looking for codes for Panasonic tx-p42gt20e. Thank you in advance.
post #1113 of 1344
LG 50PV450 Would like to check hours on new set and access other menu functions.
Thx
post #1114 of 1344
Looking for service menu codes for a Panasonic 50pz700u. I'd like to check hours. Thanks in advance.
post #1115 of 1344
I am looking for VIZIO XVT3D554SV service menu code...greatly appreciated..
post #1116 of 1344
Looking for tcp65s2 codes, thanks!
post #1117 of 1344
I would like to use the isf functions on my Benq W6000. Please give me a p/m. Thanks already!
post #1118 of 1344
hi
I am also looking for ISF Menu code on the BENQ W6000
if someone can pm me
thanks in advance
post #1119 of 1344
May I request the Vizio VF551XVT service menu codes? Thank you much.
post #1120 of 1344
Looking for Service Menu Access code for a:
TCL L32HDF11TA, please.
post #1121 of 1344
I'm looking for the service menu for my viewsonic N3250W.
If anyone finds it and can let me know I thank you.
post #1122 of 1344
Sony 55NX810 please.
Thanks in advance.
post #1123 of 1344
Hey guys need some help, according to the service manual of my TV.
The Sharp Aquos LC30HV2U
I should be able to enter the service menu by doing the following,
Using the system cable, properly connect the LCD Display Unit and the AVC System. Turn ON the power while holding down the INPUT and VOL DOWN buttons located the LCD Display Unit.
But for some reason while doing the above, the tv just starts up normally and I have no service menu or small K as I read here on the forum other sharp tv's have.
Does anyone have a suggestion on why I can't seem to be able to enter the menu ?
Hope someone can help!
post #1124 of 1344
After many failed attempts and consistently dealing with imbeciles over the matter, i've had no luck with obtaining the service menu code for the:
Dynex - 40" Class / 1080p / 60Hz / LCD HDTV
DX-40L260A12
I'd be very grateful to whoever can help me out with this!
post #1125 of 1344
DX-40L260A12
Don't know about your particular model but many Dynex SMs can be accessed by pushing the remote control input button followed by 2,5,8,0. It works on mine.
post #1126 of 1344
no luck
thanks anyways
edit:
Just found out the code for my model!
Despite having run across it on numerous occasions i simply didn't have the good sense to press the ENTER button right after!
For anyone else who wants to get into the SM of their DX-xxL260A12
all you have to do is:
Press Menu
Press 1,9,9,9
Press ENTER
Voila!
post #1127 of 1344
service code for a Proxima 6850 anyone?
post #1128 of 1344
Thanks in advance.
The sequence I've seen for other Sony's seems to work for the 55NX810:
Display, 5, vol+, power on
I did notice you have to be pretty quick. Once you get in, I've read something about 1/4 to move around and 3/6 to change values. 2/5 seemed to do something else. Beyond that, I can't figure out anything. :-(
post #1129 of 1344
I know how to access the Service Menu of my PS51D550 but I have some SM related questions.
The Movie mode White Point settings are grayed out when the TV is in the default Dynamic mode (it's always resets to Dynamic when I turn on the TV with SM).
I found a trick how to change to Movie mode -> I started to feed it with 3D signal and the default picture mode for 3D is Movie. The Movie WP settings aren't grayed out with 3D signals but I am still unable to change the values.
It seems to be locked or it's because I am in 3D mode. I don't know, but I would know:
- How can I change the picture mode (Dynamic, Standard, Movie) while I am in the SM?
- If it's still locked then how can I unlock the Movie WP settings?
The whole Expert menu is also grayed out. I don't really need that but if somebody know how I can unlock it than don't hesitate to share the knowledge with me.
post #1130 of 1344
Hey all, looking for the code for an Acer AL2216W. I've had an issue with PS3 overscan that I've been hoping to fix for a long time now. I know that someone asked for the code way back in the thread, but I've been unable to find it .
post #1131 of 1344
Vizio E550VA, please. I've searched high and low through this forum as well as the Internet in general, and all of the general Vizio model service menu codes (including combinations of the CH+/CH- keys on the side of the tv) don't seem to work. If anybody has the code known to work specifically with the Vizio E550VA (or I'd suspect / hope that any ExxxVA model will use the same code) it would be greatly appreciated.
-D
post #1132 of 1344
Looking for Panasonic th-42px60u
Thanks in advance.
Justin
post #1133 of 1344
Also looking for TCL, 40FHDP21TA
post #1134 of 1344
Hi - Can someone please share how to access service menu for Panasonic p54vt25
please pm me
Thanks in advance
post #1135 of 1344
Does anyone know service menu codes or a link to where I could find the service manual for a Westinghouse LD-4655VX led LCD? Thanks.
post #1136 of 1344
Panasonic TCP42GT25 - thank you!
post #1137 of 1344
Westinghouse LTV-32w6
Thanks so much in advance. Replaced the mainboard; the replacement displays the image upside down, need to access the service menu to adjust the orientation.
post #1138 of 1344
Can someone PM me the access codes to turn on cal-day and cal-night on a VT30?
post #1139 of 1344
Do I have to connect via rs232 to gain access?
post #1140 of 1344
Cal Day & Cal Night are Samsung modes enabled in the service menu.
