AVS › AVS Forum › Display Devices › Display Calibration › Service Menu Access Codes : Official Request Thread
Service Menu Access Codes : Official Request Thread - Page 41
post #1201 of 1293
I accessed the service menu via the hold menu on remote + on TV trick for my LG M3701C, I saw the "overscan" option under "system control 2" which was at 5% by default. I was so happy that I found the option, and set it to the lowest which was 1% but it did not do anything for my HDMI image overscan problem (using a PS3).
Anyone know how I can fix the overscan issue for this old monitor? Also, what are the ideal image settings for this?
Under system options there is also the "system" setting which is at "4-sys" by default. It changes the colour a bit, should this be left alone or should I switch it to NTSC (one of the available options) since I am in North America.
This overscan problem has really bothered me, so I am really hoping to fix it.
Any help would be much appreciated.
Under the system control option are these menu options:
System: 4-SYS
Overscan: 1% (was 5%, doesn't appear to do anything for my HDMI image)
RS-232 Host: PC (no idea what this is)
Baud Rate: 9600bps
RS-232 Select: New
AGC-L: 243 140
Audio Delay: 0
Also, is there another service menu available? When I held down the menu button, a password input box appeared and I tried entering 0000 but it was incorrect. Maybe that is just for the parental controls or something. :/
post #1202 of 1293
Can you provide the service menu remote control codes for the following Sony TV's
1. xbr 55hx929
2. kdl 46xbr2 and kdl 52xbr2
Jim
post #1203 of 1293
Can't seem to find the BenQ W6000 ISF access codes anywhere on the internet. I would greatly appreciate them! PM please, thanks!
post #1204 of 1293
Looking for info on the service menu for a Toshiba 32DT2U. Thanks!!
post #1205 of 1293
Looking for access code/process for service menu on a OLD CRT Insignia NS27RTV.
post #1206 of 1293
Hi all! I want to access the service menu on the 42LW5300 with a Monster AVL 300 remote. Is this possible? I've read all related websites and still have no clue since I do not understand remote language. I can go out and buy another remote but that would defeat the purpose of an all in one universal remote. Help is greatly appreciated!
post #1207 of 1293
Looking without success for the service menu access procedure for a 2007 Trutech T2000-FT.
Thanks in advance..
post #1208 of 1293
Hello
Looking without success for the service menu access procedure for a Yamaha DPX 1200
Thanks in advance..
post #1209 of 1293
Originally Posted by bichitade View Post
Hello
Thanks in advance..
Don't hold your breath, I have yet to get a response for anything I have requested..
Good luck!
post #1210 of 1293
Hello,
I'm looking for service menu access codes for Optoma EP780/TX780 DLP projector. This one is hard to find. Any help would be appreciated.
post #1211 of 1293
Hi!
Looking for service menu code/access for Olevia LT26HVX please.
post #1212 of 1293
Means by which to access the service menu on the Sharp Elite 70" would be greatly appreciated. Thanks!
post #1213 of 1293
I could really use the service manual for the Panasonic TH-50PHD5UY if anyone happens to have it.
My email is nick [at] nickplee [dot] com
post #1214 of 1293
I am looking for service menu access for a 2004 RCA 27V530T Chassis ITC008FBK Please oh please. Warm is very close to correct but with a slight adjustment of gray scale this set will be great for mom!
post #1215 of 1293
The SM really doesn't have much info on calibration sorry. It's more a repair manual. That being said you can find it for sale via some googling.
post #1216 of 1293
I'm looking for the service menu access code for SHARP AQUOS LC 26D40U. Thanks in advance. I'm having the green artifact described previously as "green rasta" with patches of fluorescent green on people's faces and background. PM me please if you have any solutions or the service menu code.
post #1217 of 1293
Hello,
I have two models of LG LCD's LG 32lk450 and 32lk430, and i need some help to get into the service menu to modify the "Keyless Off Hours" option. This option turns off my LCD when nobody uses it for like 2 hours (this occurs only when the tv starts automatically at a given time).
Thx in advandce.
post #1218 of 1293
Samsung UN22D5000
Need codes to access further in the SM for "colormapping".
When I enter colormapping there are no values or settings. I believe there is still a higher "FACTORY" code. Any help is appreciated!!
post #1219 of 1293
Originally Posted by RAZZ 1 View Post
Samsung UN22D5000
I'd be interested in this as well. If anyone can PM me a simple FAQ for this it would be very very cool.
post #1220 of 1293
Hello
I'm looking without success for the service menu access procedure for a Optoma SP8604 or Vivitek H5082
Thanks in advance..
post #1221 of 1293
Hi Looking for a service menu access for OPTOMA HD81 - this is the one with the separate scaler, I have tried
down down left left down left from remote while a source is playing but that did not work?
Please advise what the key press could be and from what menu etc,
Many
Thx
post #1222 of 1293
looking for service menu access for vizio VO42L
The three i have seen have not worked
Thanks in advance
post #1223 of 1293
I'm looking for the service menu for Toshiba 37BV701 G (LCD TV Set).
I found somewhere that the combo - Menu -> highlight Picture -> Press 9301 -> OK will give the service menu but it doesn't seem to work on this set.
post #1224 of 1293
Please anyone have the service menu code for LG 55LV4400,,,,led reallly need the code to try to calibrate this myself..
post #1225 of 1293
you don't need to access the service menu to calibrate an LG
try the ISF Expert1/2 modes in the user menu instead
post #1226 of 1293
it doesnt have this its a new menu and it doesnt have expert and what your saying its just movie standard vivid game thats all...thats why i asked so if anyone knows the service menu code please can i have this thank you.
no expert mode just checked.... my sons older LG has this but not this model if anyone has had experience with this model please let me know thank you again.
post #1227 of 1293
The 4400 does not have white balance adjustments even in the service menu. All you can do is user panel adjustments.
post #1228 of 1293
can i have the service menu code if you have it? did you go to service menu and see it then you can share the code if you like thank you.. if i get an isf calibration done to this model will it make a difference? thankz again.
post #1229 of 1293
The only options for calibration on this TV are user panel adjustments of contrast and brightness/black levels. The white balance controls in the service menu are not accessible/changeable. Even with an ISF calibration they are not able to adjust that. I am an ISF certified calibrator. I'm sorry to give you bad news.
post #1230 of 1293
Looking for service menu code for a Polaroid TLAC-02255.
I'm trying to turn off the horrible HDMI picture processing, which seemingly can't be done in the regular menus. I've tried all the other Polaroid codes in this thread.
