AVS › AVS Forum › Display Devices › Display Calibration › Service Menu Access Codes : Official Request Thread
Service Menu Access Codes : Official Request Thread - Page 7
post #181 of 1344
would appreciate the service menu codes for the Sharp LC-37D90U...
post #182 of 1344
Ive searched the net, Ive called LG support, and I even looked in this thread, but cant access the service menu in my LG Flatron RU-30FZ13 Widescreen HDTV.
Holding the 2 menu buttons does nothing, and the other metiod of inputing 9876 after the menu dissappears doesnt work either(just changes the channels).
Ive tried each method multiple times with no luck... I need to get into that menu to fix the overscan problem Im having when my Xbox360 is hooked up..
PM or email me..
post #183 of 1344
Hello!
The Akai service code on Bruzzi's site calls for pressing the F WHITE, AUTO, and V CHIP buttons. My remote doesn't have an AUTO button. Can someone tell me where that button is on the remote?
post #184 of 1344
Im looking for the service menu for the Vizio P50-HDM.
Thank you.
post #185 of 1344
How to get into the service menu of the Sharp Aquos 37D40U? Thank you.
post #186 of 1344
Here is how to access the service menu for the Vizio P50 HDM, I can not take credit for this since I got it from a fellow board member.
On the remote hold "Exit" for 3 seconds.
Release "Exit" and press "1, 2, 3" one after the other.
This will bring up the service menu.
To exit the menu press "Exit".
post #187 of 1344
Looking for service codes for a Pioneer 4270HD. Previous codes do not function.
post #188 of 1344
Does anybody know the code for the service menu of the Dell W3202MC?
I have tried the input-6-1-9 code that works on some older Dell TVs, but unfortunately that doesn't work for the W3202.
post #189 of 1344
Hitachi F59 series Service Menu Codes are here!
Here it is:
Press and hold the MENU key on the TV control panel, then press the REMOTE CONTROL'S MENU+8+SELECT buttons.
To EXIT Adjustment mode, press the INPUT key on control panel, or the EXIT key on the remote.
DCAM Mode:
On the REMOTE Control:
Hold down the TV key
Press the MENU key
Press the INFO key
Release the TV key
REMOTE CONTROL KEY FUNCTIONS WHEN IN DCAM MODE
INPUTS - Blue (13x9 adjust)
ASPECT - ROM Write
DAY/NIGHT - ROM Read
MENU - Remove Color
EXIT - Cross Hatch/Video Mode
INFO - Green
GUIDE - Calculation
2 - Cursor UP
5 - Cursor DOWN
6 - Cursor RIGHT
4 - Cursor LEFT
0 - RED (7x5 Adjust)
STOP KEY - Initialize
PLAY KEY - Raster Position
FAST FORWARD KEY - Phase
To get out of DCAM Mode:
Hold TV Key
Press 0 Key
Press 1 Key
Release TV Key
Use at your own risk. Always write down settings before making any changes!
__________________
http://www.avsforum.com/avs-vb/showthread.php?t=698942
post #190 of 1344
I desperately need the service code for the Hisense TA42P-HDRA 4" plasma. I screwed up some setting and I cant figure out how to fix it. Needless to say, I'm bummed. Please help. =oD
post #191 of 1344
Hi, I would love to get my hands on the service menu code for the Niko OTP-3211W.
The DVI input looks completely unsaturated and the sharpness is lacking. These adjustments are locked while using this input! Why would they do that to their customers? Anyway this is why I need this access. Any help is greatly appreciated.
post #192 of 1344
I have this set and don't have any issues adjusting the DVI input for my sony ns75h dvd player. I dont have the set in front of me, but there are preset modes (i.e bright mode, user mode, etc). maybe you are trying to adjust a locked preset mode? i have my user setting setup perfectly for dvd viewing (used the AVIA HT dvd)
post #193 of 1344
When using DVI in user mode, the options available to adjust are only brightness and contrast, but I also have have color, tint, and sharpness using any other analog connection.
post #194 of 1344
I would request JVC AV-27F802 service stuff...
Kinda old.
Dave Echelberger MCSE, A+, Net+
Computer Center of Sandusky, A Microsoft Partner
Cossack a t SpamCop d o t N et
post #195 of 1344
Can someone please PM the service menu code and options for a Sharp LC-37HV6U?
This TV has a bug that if it shuts off and then back on quickly it flashes red and need a service manual reset. This is the second time it happened and the first time it cost me 175 but they would not tell me which service manual option is the reset.
I would appreciate the help - I am dead in the water right now.
Ken
post #196 of 1344
v
post #197 of 1344
Can someone send me the service code for Sharp Aquos LC-37D40U?
post #198 of 1344
i'm dying for the code for the 27" insignia IS-TV040923
post #199 of 1344
I found the service code related info for Westinghouse LVM-37w3 from here:
http://www.bruzzi.ws/plasma-faq/showthread.php?t=192
But I'm also looking for the service manual for this display. I can't find it at http://www.servicemanuals.net
I also searched for it all over the internet but can't find anything. If you have any info about service manual for LVM-37w3 or Westinghouse LCD service manuals in general, please PM me. Thanks.
post #200 of 1344
Does anyone know the European service menu code for the Viewsonic N3260w? If so please send over a PM. It seems the European sets have a different code to that of the American units...
post #201 of 1344
I am searching for the service menu code for an RCA 32V550T, chassis ITC008. The commonly referenced codes for RCA sets, specifically, "press and hold Menu, then press and release Power, then press and release Volume+" do nothing on this set.
post #202 of 1344
Could someone PM me the service code for a 27" Westinghouse LTV-27w2 LCD TV?
Thanks a lot!
post #203 of 1344
Dose anybody have the codes for a viewsonic N2751w
Thank Dave
post #204 of 1344
Looking for a service code for a GE D52GW12. Things have fallen out of convergence on the edges and I'm not going to pay now that it's out of warranty. Thanks for any help you can give me!
post #205 of 1344
I too would like the service menu codes for the Sharp Aquos LC-37D40U. I will do a full calibration with mygretagmacbeth, colorfacts and accucal, on this set. I will will share service menu settings to anyone who can PM me the code.
post #206 of 1344
So did this method work to get into the service menu for the LVM-37w3? Holding down the volume - and the input button, and then pressing power did nothing for me.
post #207 of 1344
have you tried the code on Bruzzi's site (see the first post of this thread)?
How about sharing your settings with everyone here on the board?
post #208 of 1344
I haven't gotten to this yet. I plan to do basic calibration with SpyderTV later next week. When I find time for advanced grayscale calibration, I'll be looking into this. I hope to make an update by end of next week.
post #209 of 1344
That code did not work, I tried it several times.
post #210 of 1344
just thought i'd give it a shot. if you do find a working code, please send it to Bruzzi so he can include it for others. And I'm sure everyone would appreciate your calibrated settings as well
(i don't even have this tv, just trying to help people out).
