AVS › AVS Forum › Display Devices › Display Calibration › Service Menu Access Codes : Official Request Thread
Service Menu Access Codes : Official Request Thread - Page 12
post #331 of 1344
is the site down?
I get a 404 error when visiting the link
anyone have the service menu codes for a JVC?
post #332 of 1344
Hi,
I thought I read it somewhere on this site a while back, but for the life of me I can't find it. I'm looking for the codes to tell me how many hours I've used my Pioneer 6070 display.
Please PM me if you have it.
post #333 of 1344
Can someone PM me the Service Codes for this TV?
Thanks in advance.
post #334 of 1344
Site's back up with a new Domain Name and Host.
www.bruzziforum.com
post #335 of 1344
looking for service menu code for protron lcd tv PLTV-32CM cant find any info, any help is appreciated thanks.
post #336 of 1344
Ok I know this one is tuff but here it goes. Anyone have the access codes for the new VIZIO 50P HDTV. I think we have tried the ones posted by Bruzzi I think and we see the factory menu but can't select anything.. HELP!!!
Any input is greatly apreciated....
Together we can all see the world in true spec color..
post #337 of 1344
looking for Westinghouse W4207 code
post #338 of 1344
Looking for the same thing.
Originally Posted by KenK52 View Post
Looking for the service menu code for an Element FLX-3202.
Could be the same as the Polaroid FLM-3232.
post #339 of 1344
Better yet, where can I get the Service Manuals?
post #340 of 1344
Question:
Ok we had someone use Bruzzi's methode for getting to the access codes for the Vizio 50P HDTV and the menu comes up and he can see the options but is unable to select anything. Is there something we are missing????
post #341 of 1344
Requesting service menu for the Westinghouse W33001.
post #342 of 1344
Originally Posted by dsilver668 View Post
Question:
Request for Service Manual on a Vizio P50HDTV10A. This might help us out!
post #343 of 1344
Try the code for Polaroid (many models made by Prima - XOCECO) posted on my site. Click on my signature.
The following link has some service manuals. Your Model is listed but unfortunately not available.
But you might try another model to see if it's similar to yours.
http://www.worldwideelec.com/apex_asc_site/apex.html
Question:
I wish I could help but I have no experience with Vizio.
post #344 of 1344
oh, if that don't work, try Menu 8+8+8+8 which is what my Prima responds too.. (service menu is COMPLETELY different though)
post #345 of 1344
Oops, with all the confusion of changing the Webhost I forgot to post your code on my site. Sorry!!!
BTW: do you have any aditional info you can share like which buttons change values / menus / pages ???
Thanks again Hakemon.
post #346 of 1344
yes, I can help there...
Once the menu is up, the up and down arrow keys will move the cursor up and down.. the right arrow selects an item from the main screen.. from the second-screen, where the values are, using left and right change values...
to go back to the main screen, you push Menu.. to exit, you push Menu again..
here's the stupid part.. when on Component video, you have geometry settings there.. what you do there affects only component.. Now if you are on any of the NTSC inputs (Svideo, TV, composite), any settings there will DIRECTLY affect the Component.. (so word of advice, calibrate the NTSC ones first, THEN move onto the Component)..
Also, in Component, EACH resolution has it's own white balance... and 480i, 480p, 720p, and 576p, and 576i all share the same geometry settings.. 1080i has it's own...
confusing, VERY..
post #347 of 1344
I had already stumbled on that site, downloaded a service manual for a similar sounding model. I'm not real comfortable relying on it, however. I appreciate your looking into it for me.
post #348 of 1344
Looking for lcd toshiba 20vl63 service menu code. Thank You!
post #349 of 1344
...I wish I could help but I have no experience with Vizio.
It's an LG panel... Any chance we could dig up enough info to figure out which LG is it's cousin and go from there?
post #350 of 1344
Click on my sig and check out the codes for Toshiba TVs.
Yes, we can do that.
But first try the alternate code (top) I posted yesterday for the Vizio.
post #351 of 1344
You're welcome. I'll see if I can find a place that sells Apex SMs.
post #352 of 1344
confusing, VERY..
Yup. kind of confusing...
I added only the info about the buttons.
Thanks again.
post #353 of 1344
I would be most appreciative.
post #354 of 1344
i've tryed all those codes.it's not working. can you give me something else? thanks!
post #355 of 1344
i found the code
Service Menu is entered by pressing 9, 3, 0, 1 keys on the remote controller when the Picture icon is
highlighted in the Main Menu.
Service Menu has 3 sub-menus. These are:
Options
Adjustments
Selections.
Navigation through these menus can be done by pressing OK button. Every adjustment made in this
menu is saved automatically.
post #356 of 1344
That's Great !!!
Thanks for the info gojil79
Do you know which button change values and how to exit the service menu???
post #357 of 1344
That's Great !!!
for change values :vol - ,vol+ ,p - , p+
for exit to the service menu : menu
post #358 of 1344
Unfortunately I only have one access code for Westinghouse TVs and I don't think it'll work on your Model.
Got it from PeterS.
He posted the info here:
http://www.avsforum.com/avs-vb/showt...&&#post7873814
Also try this:
With the TV on, press mute, display, mute on the remote.
Thanks but this does not work on the Westinghouse w3212HD. No one seems to have this code. Any ideas on how we can we get it?
post #359 of 1344
Hello,
If anyone knows the service menu code for this model? It would help alot!
Overscan problem with Nintendo Wii!?
Thanx
post #360 of 1344
I tried the new code but, wasn't able to get in. I was able to enter a Factory Mode menu by depressing "Channel +" and "Channel -" simultaneously. This brought up the following options:
1) Burning Mode
2) Factory Reset
3) NVRAM Reset
4) EDID Write Pro
5) Password Reset
Seems like that's what I'm looking for but, I wasn't able to access any of the options. I can scroll through 'em, just can't figure out how to select an item for more info.
There's an LG rep in a different forum I've been visiting but, I'm not sure how anxious he'd be to help with identifying such a distant relative Any thoughts on that or in finding a service manual on this puppy? Many thanks for the help so far!
EDIT: Vizio P50HDTV10A, FW v. 5.2.168 14
