AVS › AVS Forum › Display Devices › Display Calibration › Service Menu Access Codes : Official Request Thread
Service Menu Access Codes : Official Request Thread - Page 15
post #421 of 1290
Hi!
I'm looking for a service menu code for Toshiba MT-200 and LG AN110, if anyone has it please PM me with the info.
post #422 of 1290
The service menu is URGENTLY needed for the new VIZIO GV47L .
The existing methods don't work on this new model.
Thanks for your continuing help!
post #423 of 1290
looking for Vizio VX32L service menu... if you have please PM me.
post #424 of 1290
Looking for service menu code for Westinghouse LTV-32W6 (if anyone has figured it out yet). The stated operation for the Westinghouse sets does not work for this model. Thanks!
post #425 of 1290
I'd pay good money for that code!
post #426 of 1290
Count me in on that request. Thank you in advance for what ever you find. I am looking for the code to get into the service menu for the gv47l.
The panel buttons on this set are touch sensitive and the existing codes do not appear to work.
post #427 of 1290
i was the one that asked for the service menu of the european at2720, the code mentioned above to display the firmware works, my firmware was the same that the guy on the post, and one more thing, (thats and offtopic), anyone knows that if the acer at2720 european model have HDCP on any of his HDMI conector (acer spain , and acer UK dont know :S)
post #428 of 1290
I need it to see if I can turn off the overscan.
post #429 of 1290
Thank you to post your Acer AT2720 FW version.
(I repeat: HV9E_CMO27_V1.004 OP28_01_41 B)
Yes all HDMI ports included HDCP in every case in every device.
Devices coming from Acer too.
This told all german leaded technical user.
In the case of DVI you must ask the company that designed this device port.
But the european Acer ATxx20 devices has no DVI.
post #430 of 1290
Hello, please count me in on the requests for the Viewsonic N2750w, I have been researching it and have not found one yet.
I found this site (great community here) and it had a link to a page with lot's of manufacturer's but when I clicked on Viewsonic the instructions were vague and I'm not sure it was even meant for that specific model.
Thanks in advance.
post #431 of 1290
Hi,
I've been searching and searching for the code to access the service menu for the Sony KLV-40U100M. Please help!
THanks!
post #432 of 1290
Hi,
Please someone send me the way to get to Factory menu for Vizio VX32L, it is not the same as the two method I found on http://www.bruzziforum.com/vbf/showthread.php?t=26
appreciate your time.
Vishal
post #433 of 1290
anyone know how to get into the sm on the Olevia 232v?
post #434 of 1290
Hi there,
Can someone please provide the code for a polaroid PLA-4205 (plasma) service menu?
From what I understand It is the same tv as a Prima PS-42D8.
I have tried a Prima code (Menu 8+8+8+8), no good.
I cant try the listed polaroid code, as it involves {SLP}, {MUTE}, {AV}, {MENU}. there is no AV on my remotte (as someone stated in an older post)
I need to adjust the color level and tint on this Monitor for my component and DVI inputs. The standard user menu doesnt allow for that
post #435 of 1290
Originally Posted by BirdyMan View Post
I was wondering if you still have this set? My cable box is putting out 1080i on HD programs, but when I press the info button on the WF32L6 controller, it say's it's only doing 720p? On all HD stations? Shouldnt I be getting 1080I? Does your unit do this?
Also, did you ever get the code for this unit?
Thanks in advance,
Birdyman
I have the same model that's doing the same thing. I've been wondering if it might not be the signal coming from my cable company. I live in Longview, TX. Where are you?
I saw someone say:
Do you use a cable or satellite STB? If so, check your menus and check the output. It could be set to output 720p. If so, then the STB is deinterlacing and downscaling all 1080i signals to 720p prior to inputing the signal to your set. You could change the output to 1080i and then your set would have to deinterlace and scale.
but that's not possible with the set top box I have: the Motorola DCT6400. It seems the unit is capable of doing many things more than I'm afforded by my cable company.
Another problem I have is with the picture quality on many SD channels. On most there is a very annoying motion artifact. When there is movement, the darker areas of the image lag behind the brighter areas. It's as if the image has been seperated into 4 or 5 different screens that move idendently of each other. It's most annoying on faces. I know this sounds like ghosting, but it's something different. How bad it is seems to be related to the signal quality. I think this might also be my cable company's fault.
post #436 of 1290
I followed the links to Bruzzi's Forum with the Service Menu codes. The process for SHARP LCDs is rather simple. However, it doesn't work for my LC37D90U. I follow the instructions but I never see the little "k" in brackets.
Has anyone been successful with the SHARP instructions?
TIA
post #437 of 1290
for the daytek dm42a
In order to get into factory mode, it's
Display > 1 > 1 > Line
maybe it will work for the other dayteks
post #438 of 1290
I could really use the code to enter the service menu on my Insignia NS27 LCD TV. None of the codses listed here http://www.bruzziforum.com/vbf/showthread.php?t=33 work for my TV. Any info would be GREATLY appreciated.
post #439 of 1290
One question.
Are there news about the Acer Atxx20 serie service menu code?
At2720
At3220
At3720
At4220
At4250
post #440 of 1290
Can someone give me the code to access the service menu on my Toshiba 30hf66?
post #441 of 1290
I have a Panasonic 26LXD600a LCD with integrated digital tuner. I got into service menu 1 the other night using the "treble to min, bass to max"
Any help...
post #442 of 1290
Hello. I'm looking for the service menu code for a Westinghouse 27w7. Thanks.
post #443 of 1290
Can someone PM me the service code for Sharp Aquos LC37D40U.
Awais
post #444 of 1290
Does anyone have codes for any epson projector - specifically the EMP-TW700 also known as the Pro Cinema 810, but any epson code would help.
post #445 of 1290
Does anyone have the service menu code for the Syntax Olevia LT37HVS? Please PM the code. Thanks!!!
post #446 of 1290
I would lioke to get the code for a Optoma H77.
I already had it, but can't find it anymore
Can anybody help?
post #447 of 1290
I noticed there are no codes for Funai televisons. Anyone know how to get a service menu code for a Funai TV?
post #448 of 1290
I'd greatly appreciate it if someone could post the way to get to the service menu on the Sharp LC-20SH21U. The instructions for Sharp TVs don't seem to work on this model.
post #449 of 1290
I am again...
Now, have anybody news about the Acer Atxx20 serie service menu code?
At2720
At3220
At3720
At4220
At4250
post #450 of 1290
Bruzzi,
I tried the codes on your site for the Mitsubishi's. The 37131 doesn't seem to go into a service menu with any of those. I bought a service manual, and that gives instructions for getting into the options menu, but not the service menu.
Has anyone gotten into a service menu on this TV where you can actually make video adjustments?
