I really need the codes for a sylvania 42" plasma. I've tried all of those listed under the Philips/Magnavox/Sylvania link with no success.
Any info on this will be greatly appreciated.
Just checking if anybody has managed to find service menu codes for the Akai PDP5016H (or any newer akai plasmas). The code listed on Bruzzi's site don't work for this model.
I recently purchased this set from Costco and the thing is an awesome set. The only problem I have is that there is no backlight level control and it is too bright at night. DOes anyone know how to get to this adjustment? Thanks!
Can someone get me the Service Menu code for this TV? I have tried the [MENU], [8], [8], [8], [8] with no luck. I also tried SLP, MUTE, MENU, AV but I don't have an AV button on remote.
White level is WAY TOO HIGH on component video and I can not fix through normal adjustments.
Does Anyone have the "Factory Default Service Menu Codes" for the
Panasonic TH-50PX60U?
I accidently changed something when I was checking the hours used.
I used the general Philips service code for my 26PF5321D/37 and now there is no picture at all. Audio works but there is simply no picture. Anybody know how to reverse this effect?
Requesting code for LG 32LX1D, holding down the menu button as described in Burzzi's forum leads to a 4-digit password screen, which is not the default 0000 or 7777 or the other 20 combinations Ive tried. =) Thanks ahead of time!
1) connect a source to any input ( scart, hdmi, dvi, pc , av3 ecc.) and turn on that isource
2) turn on the tv and select that input
3) Press POWER, channel UP and volume DOWN on the TV simultaneously for 3 seconds, a red screen flashes.
4) press menu to access the factory video mode related to the input you chose.
I could find only these menus so far , anyone could find an "aspect menu" similar to that present in 3705?
Service menu code needed for Polaroid 19 inch LCD Model Number FLU-1911S
Need to adjust picture width in 16:9 aspect. Found Bruzzi's list of codes, tried the ones given for Polaroid, (SLP,MUTE,AV,MENU) but no luck. My remote does not have SLP or AV buttons. Does anyone have any ideas please.
Bought this tv in Switzerland last October, bowled over by low power consumption (use in RV) and brilliant picture quality. Alternative to self-fix is a 1600 mile round trip to Switzerland to return to shop and wait "how long?" for service centre adjust. Hoping someone has right code. Thanks in advance.
I have searched the forum and many other websites i can not find the code for for the service menu for a olevia 437 i tried buzz's codes the (source) + (Channel +) with no luck and someone PM them to me or give me a link or anything thanks!
