AVS › AVS Forum › Display Devices › Display Calibration › Service Menu Access Codes : Official Request Thread
Service Menu Access Codes : Official Request Thread - Page 31
post #901 of 1342
Originally Posted by ed_in_tx View Post
All 3 of my Sonys (but not an SXRD) have the same code - with set Off, press remote keys Display, 5, Vol Up, Power. To save and exit, power Off. Write down the settings or take pictures first before adjusting anything!!
Some have an additional self-test screen, same key sequence except press Vol Down instead of Up.
Thanks, Ed. Perhaps there's something obvious that I'm missing. I tried your suggestion, which resulted in "something" happening. But I didn't see any new setup functions when I went into the menus. Instead, upon power-up, the tv displayed the following green text overlayed on the program material....
VERSION 0 SERVICE
VER_DISP_ENBL 0 TV MICRO
This text wasn't inself "cursorable". When I went into the menus while the overlay was visible I saw no change in the available screen setup functions. Any thoughts?
post #902 of 1342
I am looking for the service code for a Proxima dp8000hb or Ask C300hb.
I have 2 of these projectors and they both are in need of software adjustment. I can access the service menu but I do not know the code. Please PM Thank You!! Is the remote needed for this??
post #903 of 1342
Hello, I'm looking for the service menu code for an AOC L32W961 32" LCD.
Thanks...
post #904 of 1342
I am looking for the service menu access for a panasonic 65v10
thank you and happy new year!
post #905 of 1342
If someone could pm me the code to the magnavox 32mf339b or 32mf339b/f7
that would be great!
post #906 of 1342
I need service menu access for Panny TC-P50U1
post #907 of 1342
I'm looking for access to the service menu of a Pioneer PDP-5020FD. Thanks
post #908 of 1342
Hello,
I am looking for the access code for a panasonic TC-P42G10. Thanks
post #909 of 1342
Hello,
I am looking for the access code for a panasonic TC-P42G10 to gain access to the service menu. Thanks
post #910 of 1342
I am looking for the access code/sequence for Sharp LC42SB45UT to gain access to the service menu. Thank you in advance!
post #911 of 1342
I did buy the remote. Still looking for the service code for a Proxima dp8000hb or Ask C300hb. Please PM
post #912 of 1342
Hi. If you had information for Vizio SV420M that would be awesome. Thanks.
post #913 of 1342
I need the service menu code for a westinghouse TX-42F430.
Thank You.
post #914 of 1342
Hi everybody. Can please helpme to acces to service menu of vizio VO22L FHDTV10A. Thanks in advance!
post #915 of 1342
Looking for the Insignia NS-L42Q-10A. PM me if anyone has the service manual or can just tell me how to access the service menu. Thanks.
post #916 of 1342
Looking for the service code for the Prima LC-3218p, thanks in advance
post #917 of 1342
Do you have the codes for a Panasonic 42 inch PZ 85U ?
Also, do you also have the best calibration codes for the tv?
I am a rookie and this will be my first attempt at this.
Thanks !
post #918 of 1342
Do you have the service menu codes for the Toshiba 62MX196? Thanks in advance.
RCG
post #919 of 1342
I would like information about the service menu on a JVC LT-46SL89. Please PM me. Thanks in advance.
post #920 of 1342
Just picked up a Toshiba 40RV525R for the bedroom. Calibrated it with a DTP94 and HCFR and it looks really good but I would like to tweak it just a tad. Anyone know how to get to the service menu on this set? Thanks.
post #921 of 1342
So can I ask everyone here a question? Has anyone actually gotten a Service Menu code? Cause so far I have to says Ive gotten nothing...
post #922 of 1342
I have not.
post #923 of 1342
I need to know how to enter the service menu for a Samsung LN-S3251D. Thanks in advance!
post #924 of 1342
Yes. Bruzzi used to maintain a pretty comprehensive list of service menu codes and there was a website that listed them but it is no longer available. Bruzzi has not been active on AVS for about seven months now, I'm not sure what happened to him.
post #925 of 1342
Thanks !
I have not received mine, but I would like to tweak it before the Super Bowl and the Olympics begin.
Do you 'know' him well enough to email him and ask him to help us ?
post #926 of 1342
Raymond, I don't know if this will get you into the service menu of your pz85 or not but here is how I access the service menu for my pz800.
Enter the service menu by taking the volume all the way to zero, release, then hold the VOL- button on the front of the TV set and press INFO three times on the remote. Release the VOL- button on the front of the TV set, and after a couple of seconds the service menu will be displayed in the top left corner of the screen.
To exit the service menu, either press Power on the remote or on the front panel of the TV set.
Entering the service menu can be very dangerous so make sure you write down all values or use a camera to take pictures of the screens before you make any changes. Good luck.
post #927 of 1342
Thank you, I will try it this week.
post #928 of 1342
I need the Service Manual for TC-P65S1 in pdf form please
post #929 of 1342
How do I access an Insignia NS-P501Q-10A?
post #930 of 1342
I'm looking for service menu codes for an AOC Envision L22W898.
