Originally Posted by BloggingITGuy
Thanks for the advice. I've already contacted the local RBH dealer in the area.
Hopefully, they do in house trials/have a very liberal return policy as I don't put much stock in in-store listening.
The only way to truly tell how a speaker will perform in your home is to listen to it in your home, connected to your equipment, calibrated by you.
Dont forget to look into the 661 se/r's which arent listed on RBH's site. I use them in a vertical setup behind a transparent screen.
On a side note, its getting to that upgrade time for me and Im at the point where I want all RBH. Im set with the front and subs but now need to start looking into the surrounds. I want the direct(not bipole), but they are a little to big for my setup.
Anyone have any luck with the inwalls? Something comparable to the 61se's????
