I'm having trouble with delay when using my H1 as my mce remote in the guide section of WMC. Here is my setup:
Harmony one
This IR receiver:
http://www.amazon.com/Windows-Contro.../dp/B00224ZDFY
Sony 46z4100
Sony STR-DG510
W7 64bit media center
I couldn't seem to find a code in the database that works for the IR receiver, so I eventually just used the remote to RAW program it. Everything works as it should, except there is significant delay when using the guide in WMC. The OEM remote works just fine with the guide. My IR receiver lights up when it receives a signal, and I noticed that is it slightly delayed when signals are sent from the H1 when compared to the OEM. I've tried changing the inter key and inter device delays to 0, changing the number of repeats to 0, as well as multiple combinations of the above, including my other components. No luck. I called logitech support, and the guy pushed me up to level 2 support, but no one's available on the weekend. Anyone here have any other suggestions to try?
Edit: I thought I'd update this post for others who may have purchased this remote. Logitech finally returned my call today and the fix was pretty easy. They analyzed my raw signals, and "trimmed" the end of each raw signal I had programmed. Works great now, is much more responsive, and I have no complaints.
