Originally Posted by suspect21
Ok I Am Having The Same Problems How Ever I Have Direct Tv With The Standard White Remote.....it Only Gives Me 5 Codes....and The Scan Was Not Helpful At All....along With This....i Can Only Turn It On With 1 Code Or Off With 1 Code.....is There A Code To Allow Me To Turn It On And Off And Volume Up And Down???? Please Help
ok I just edited this post...here are the codes and what they do...there is a seperate "993" code to enter for the volume to go both up and down however no code to turn both on and off the reciever....
CODES:
30135-on
30842-off
31298-off
31320-on
31531-on
and now I am having problems with the volume to work....(UPDATE)- ok for some weird reason I entered in "30842" pressed power shut it off.....than entered in "30105" pressed power and turned it on...and for some odd reason the volume both now works up and down....however just cant turn it off....O-well 1 function isnt going to kill me....I can get up and hit the power switch for christs sake.....if any one finds a way to use on/off and volume up/down...please reply.....good-night guys =)
CODES:
30135-on
30842-off
31298-off
31320-on
31531-on
Sorry but the directv remote will not give you something that onkyo oem remote doesn't even give you, a power toggle. the best code to use is 30135, to get the volume keys to work there has to be a tv code programmed to the tv device or the volume won't work. to punch through the onkyo volume to all devices:
1, av1 or av2
2. press and hold MUTE & SELECT for two blinks
3. enter 9 9 3
4. press SELECT
