Originally Posted by
Krishna
Also, I'm looking to hang them flush on the wall at about 7 ft height, with the base side against the wall (similar to how Mirage recommends one mount the Omnisats) Any ideas on how to do this? At this point, I'm considering using strap hangers used to hang pictures, and maybe putting picture hooks on the walls to hang them on. The downside of course, is that I'd need to put holes in the speaker cabinets. Are there any other alternatives? I looked at the Omnimount, but it appears to make the speaker stick out from the wall.
Here's a recommendation from Owner's Manual, Page 3:
The OMNI 150 is designed to be used as a front left or right speaker, or as a
rear channel speaker.When installing the OMNI 150 bookshelf speakers to a
wall, there is an insert built into the back of the speaker, located above the input
terminals.The threaded insert is designed specifically for the MIRAGEĀ®
Macromount bracket, which is available from your local authorized MIRAGEĀ®
retailer. Please see diagram 4.
