Hi everyone and thanks for all the help I've gotten already to get to the point of at least planning my first theater. This is the thread I'll use to post updates on my progress. I am not sure yet what I will be doing (maybe all of it) and what I will subcontract out. Also, I will be finishing about 800 sq ft of basement all told, so my schedule is to have it done in a year from January 1st.
First off, I have just finished my basic layout diagram for the 57th time. I end up with a theater that is 19'6" deep by 11'6" wide. The pool table must stay (WAF), or I would use a much larger area. The 11'6" width is basically contained by HVAC and support poles I am dealing with in the basement.
I don't have 5 posts so I can't link to my drawing yet, but I will shortly.
I am approaching this as a learning experience and will setup the room from a standpoint of upgradeability. Right now I will be using 5.1, but will prewire for at least 7.1. I plan on "overplanning" for all possible wiring and using PVC with wire pulls for all drops.
What I have:
Infocus LP540 projector (new, got it so cheap I can't complain)
Optoma 106" 16:9 Greywolf screen (again, too cheap to pass up)
What I plan on:
Polk R30 for L & R, Polk R15 for surrounds.
Subwoofer and Center channel TBD.
Two rows of 3 seats (most likely Coaster Showtime)
Buttkickers? Maybe. Will wire for them in case.
I am planning at this point to do a true drywall ceiling in the theater and a drop ceiling elsewhere.
Planning on a Navy Blue color scheme with GOM over acoustic treatments on the walls.
Dricor for all finished floors.
External venting to projector and equipment closet.
No real issues with sound containment in the room.
Bass traps? Still need to figure it out.
Equipment Closet is under the stairs.
Completely unsure as to what equipment will go in there.
I'll post here and keep you updated. As soon as I clear out the basement of "stuff" I'll post some before pictures.
My schedule is to pull permits in the first week of January, and get the basement ready for construction by the second week. By then I will have decided whether I think the 1 year old and the 3 year old are going to allow me enough time to do the framing myself or if I want to hire it out and just get it done.
Thanks for all the planning help the past few months (even though you didn't know it) and thanks for all the future help!
What I have:
What I plan on:
The good news is that I am on the homestretch with waterproofing, some demolition, framing, wiring, Dricore floors, and drywall almost done. I kept finding myself working on it like gangbusters for a few weeks and then doing nothing for a month or more, rinse, repeat. The completion date was supposed to be in time to watch the last Superbowl in HD on my PJ in the theater instead of upstairs on a HD RPTV. Didn't happen.
