Originally Posted by otk
yes, forget about bi-wiring, forget about using RCA cables, leave all the jumpers in place on all 3 binding posts. go into your receiver, set subwoofer to "none". that way the LFE channel and any redirected bass will be seamlessly mixed to your front towers via the speaker wires
do you have any channels set to "small" ?
Def Teck told me to run speakers on large so I would get the best bass.I not sure of the proper set up. Should I set them to small ? Man, I could have saved a ton of money on sub cables and speaker wire !!!!
![Contact [Blu-ray]](http://cdn.avsforum.com/9/93/50x50px-ZC-93e07e41_B001AQT0RC-51tEC3sZBmL.jpeg)
