Originally Posted by g_bartman
I guess I'm kind of old school, or just old. I cant imagine demoing speakers using a video game but that's going to be a primary use for you so it makes sense. Save the 400 bucks and just get a good surge protector. May be he gets a bonus for selling one of those. A lot of people (myself included) have been going with id subwoofers. They offer a lot of bang for the buck. Here is an example
http://www.svsound.com/products-sub-box-10nsd.cfm
I used 12 ga wire from monoprice, 14 ga would be fine too.
ya, since its for gaming almost exclusivly (like i said 90% gaming 10% movies 0% TV/music) that was a no brainer for me.
both you and USCR mention ID subwoofers
Originally Posted by USCRx
kenshin-dono
I have that setup.
7004s, 2002, 2 X bp2x, + id sub.
IMHO, the sound was very good even w/o the separate sub and I'm in a 3000+ cubic foot room. I kept the 7004s as full range w/no sub. That being said, adding the separate sub has made a big difference in overall performance.
Good Luck.
kenshin-dono
I have that setup.
7004s, 2002, 2 X bp2x, + id sub.IMHO, the sound was very good even w/o the separate sub and I'm in a 3000+ cubic foot room. I kept the 7004s as full range w/no sub. That being said, adding the separate sub has made a big difference in overall performance.
Good Luck.
espeically USCR's post, since he has almost my exact setup
.. whats an ID subwoofer? the brand you linked to was SVS, and between the 2 id go for the 12" version
http://www.svsound.com/products-sub-box-pb12nsd.cfm
is ID some kinda technology? whats it do? im really looking for more advice on what kind of sub to get here, what should i really be looking for? wattage? size? what kinda frequency response numbers do i want? hell what do those numbers even mean, if someone could explain that. I always thought the first number should be lower, but i dont know about the second number. The abyss actually had a higher first number than most other ones i was looking at
23-120 Hz ±3dB
ungh.
the pb12-nsd seems to keep coming up in a lot of threads
but its so much cheaper.. im worried i'll have that same muddy sound i had with the supercube, i just want it to sound as crisp as the abyss did. plus svs doesn't seem to list specs which i find odd.. not that id understand them anyway =(
also, anyone else got any coments on the whole power conditioner thing? whats the worst that would happen if i dont bother getting one, will my sound quality REALLY be effected?
![Contact [Blu-ray]](http://cdn.avsforum.com/9/93/50x50px-ZC-93e07e41_B001AQT0RC-51tEC3sZBmL.jpeg)
....I know I used a variety of sources for the data, including Chet's info that otk just re-posted, as well as some reviewers' bench data. (I suspect red data may indicate conflicting sources.)
Now all my equipment gets protected with a monster cable unit.
